cgal-discuss - Re: [cgal-discuss] No lib folder in the cgal installed directory
  • To:
  • Subject: Re: [cgal-discuss] No lib folder in the cgal installed directory
  • Date: Wed, 18 Apr 2012 12:06:47 +0300
I think may be this link will be useful to follow:
http://acg.cs.tau.ac.il/cgal-at-tau/installing-cgal-and-related-programs-on-windows
Regards,
On 18 April 2012 12:03, Laurent Rineau (GeometryFactory) <> wrote:
Le mercredi 18 avril 2012 01:51:16 daisy a écrit :
> windows, vs2005, boost1_4_7, cmake2.8.7, no qt
> After I installed the cgal and use cmake configured it, I found no lib
> folder under the directory C:\Program Files\CGAL-3.5
CMake is only a configuration tool, that generates the way to build the
libraries. You need to build the solution that was created by CMake.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory           http://www.geometryfactory.com/
Release Manager of the CGAL Project       http://www.cgal.org/
