cgal-discuss - [cgal-discuss] Re: No lib folder in the cgal installed directory
  • To:
  • Subject: [cgal-discuss] Re: No lib folder in the cgal installed directory
  • Date: Wed, 18 Apr 2012 02:29:59 -0700 (PDT)
Yes, I think the problem is not the cgal itself. When I use cmake configure
the cgal, there are some warnings, but I don't know what shall I do with
them:
/CMake Warning (dev) at C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake:85
(INCLUDE):
File C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/FindPackageHandleStandardArgs.cmake includes
C:/Program Files/CGAL-3.5/cmake/modules/FindPackageMessage.cmake (found
via
CMAKE_MODULE_PATH) which shadows C:/Program Files/CMake
2.8/share/cmake-2.8/Modules/FindPackageMessage.cmake. This may cause
errors later on .
Policy CMP0017 is not set: Prefer files from the CMake module directory
when including from there. Run "cmake --help-policy CMP0017" for policy
details. Use the cmake_policy command to set the policy and suppress this
warning.
Call Stack (most recent call first):
C:/Program Files/CMake 2.8/share/cmake-2.8/Modules/FindZLIB.cmake:84
(INCLUDE)
src/CGALimageIO/CMakeLists.txt:16 (find_package)
This warning is for project developers. Use -Wno-dev to suppress it./
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/No-lib-folder-in-the-cgal-installed-directory-tp4567084p4567169.html
