- To:
- Subject: Re: [cgal-discuss] Re: No lib folder in the cgal installed directory
- Date: Wed, 18 Apr 2012 11:56:51 +0200
daisy
writes:
> I know the latest version is 4.0. But I have to install the 3.5 because it
> support vs2005 which is linked with some other software I installed. I think
> the problem is that the cmake didn't configure the cgal successfully. Please
> see my next reply.
That is a really bad situation. The benefits of that other package have
to really high to outweigh the problems caused by VS2005. Those problems
include that it is close to impossible to help you because no one still
has the software around that is required to reproduce your most of your
problems and no one is likely to back-port fixes to it. If possible, you
should consider contacting the vendor of the software to update their
software.
Cheers,
Philipp
- [cgal-discuss] No lib folder in the cgal installed directory, daisy, 04/18/2012
- Re: [cgal-discuss] No lib folder in the cgal installed directory, Sebastien Loriot (GeometryFactory), 04/18/2012
- [cgal-discuss] Re: No lib folder in the cgal installed directory, daisy, 04/18/2012
- Re: [cgal-discuss] Re: No lib folder in the cgal installed directory, Philipp Moeller, 04/18/2012
- Re: [cgal-discuss] No lib folder in the cgal installed directory, Laurent Rineau (GeometryFactory), 04/18/2012
- Re: [cgal-discuss] No lib folder in the cgal installed directory, Sweety Pie, 04/18/2012
- Re: [cgal-discuss] Re: No lib folder in the cgal installed directory, Laurent Rineau (GeometryFactory), 04/18/2012
