- To:
- Subject: [cgal-discuss] using a Point class from another library
- Date: Tue, 24 Apr 2012 10:01:00 +0200
I have managed to make Polyhedron work with my Point class, but when I want
to read it from an .off file,
this function:
template < class Point> inline
Point&
file_scan_vertex( File_scanner_OFF& scanner, Point& p) {
typedef typename Point::R R;
typedef typename R::RT RT;
double x, y, z, w;
scanner.scan_vertex( x, y, z, w);
if ( w == 1)
p = Point( RT(x), RT(y), RT(z));
else
p = Point( RT(x), RT(y), RT(z), RT(w));
return p;
from the file "File_scanner_OFF.h" expects my point to have a constructor
with 4 arguments. For a simple
example Point class that I wrote, I have added this without a problem, but if
a Point class is coming from another
library, it is a problem. I cannot change the library Point class. What
should I do?
Option 1) Inherit from the Point class of the other library and add a dummy
constructor, counting on
implicit casting every time i call a method on the Point to cast it
up?
2) Change the .off File_scanner and adapt it somehow?
I don't need homogeneous coordinate representation of points, so this kind of
constructor is not necessary..
Working code is attached.
Thank you!
Tomislav
#include <CGAL/Simple_cartesian.h> #include <CGAL/Polyhedron_3.h> #include <iostream> #include "point.hpp" #include<fstream> #include <CGAL/IO/Polyhedron_iostream.h> // A face type with a color member variable. template <class Refs> struct My_face : public CGAL::HalfedgeDS_face_base<Refs> { CGAL::Color color; }; template <class Refs, class T, class Point> struct My_vertex: public CGAL::HalfedgeDS_vertex_base<Refs, T, Point> { double x; My_vertex() : CGAL::HalfedgeDS_vertex_base<Refs, T, Point> () {}; My_vertex(const Point& p) : CGAL::HalfedgeDS_vertex_base<Refs, T, Point>(p) { }; My_vertex(const Point& p, double X) : CGAL::HalfedgeDS_vertex_base<Refs, T, Point>(p), x(X) {}; }; // An items type using my face. struct My_items : public CGAL::Polyhedron_items_3 { template <class Refs, class Traits> struct Face_wrapper { typedef My_face<Refs> Face; }; template <class Refs, class Traits> struct Vertex_wrapper { typedef typename Traits::Point_3 Point; typedef My_vertex<Refs, CGAL::Tag_true, Point> Vertex; }; }; // Define the PolyhedronTraits_3 concept and take the Point directly from point.hpp template <class Kernel> struct My_Polyhedron_traits_3 : public CGAL::Polyhedron_traits_3<Kernel> { // Redefine Point_3 to be my Point<double> typedef Point<double> Point_3; typedef typename Kernel::Plane_3 Plane_3; My_Polyhedron_traits_3() : CGAL::Polyhedron_traits_3<Kernel>() {}; My_Polyhedron_traits_3(Kernel kernel) : CGAL::Polyhedron_traits_3<Kernel>(kernel) {}; My_Polyhedron_traits_3(const My_Polyhedron_traits_3& r) : CGAL::Polyhedron_traits_3<Kernel>(r) {} My_Polyhedron_traits_3& operator=(const My_Polyhedron_traits_3& r) { CGAL::Polyhedron_traits_3<Kernel>::operator=(r); } }; typedef CGAL::Simple_cartesian<double> Kernel; //typedef CGAL::Polyhedron_3<Kernel, My_items> Polyhedron; typedef CGAL::Polyhedron_3<My_Polyhedron_traits_3<Kernel>, My_items> Polyhedron; typedef Polyhedron::Halfedge_handle Halfedge_handle; //typedef CGAL::Simple_cartesian<double> Kernel; typedef Kernel::Point_3 Point_3; //typedef CGAL::Polyhedron_3<Kernel> Polyhedron; typedef Polyhedron::Facet_iterator Facet_iterator; typedef Polyhedron::Halfedge_around_facet_circulator Halfedge_facet_circulator; int main() { // Kernel::Point_3 //Point_3 p( 0.0, 0.0, 0.0); //Point_3 q( 1.0, 0.0, 0.0); //Point_3 r( 0.0, 1.0, 0.0); //Point_3 s( 0.0, 0.0, 1.0); typedef Point<double> Point; Point p( 0.0, 0.0, 0.0); Point q( 1.0, 0.0, 0.0); Point r( 0.0, 1.0, 0.0); Point s( 0.0, 0.0, 1.0); //Polyhedron P; //P.make_tetrahedron( p, q, r, s); Polyhedron P; std::ifstream is ("input.off"); is >> P; // Write polyhedron in Object File Format (OFF). //CGAL::set_ascii_mode( std::cout); std::cout << "OFF" << std::endl << P.size_of_vertices() << ' ' << P.size_of_facets() << " 0" << std::endl; std::copy( P.points_begin(), P.points_end(), std::ostream_iterator< Point >( std::cout, "\n")); for ( Facet_iterator i = P.facets_begin(); i != P.facets_end(); ++i) { Halfedge_facet_circulator j = i->facet_begin(); // Facets in polyhedral surfaces are at least triangles. CGAL_assertion( CGAL::circulator_size(j) >= 3); std::cout << CGAL::circulator_size(j) << ' '; do { std::cout << ' ' << std::distance(P.vertices_begin(), j->vertex()); } while ( ++j != i->facet_begin()); std::cout << std::endl; } return 0; }
#ifndef POINT_HPP #define POINT_HPP template <class T> class Point; template<class T> std::ostream& operator << (std::ostream& os, const Point<T>& v); template<class T> std::istream& operator >> (std::istream& is, const Point<T>& v); template<class T> class Point { private: T v_[3]; public: struct R { typedef T RT; }; Point() : v_() { } Point(T c1, T c2, T c3=0) { v_[0] = c1; v_[1] = c2; v_[2] = c3; } Point(T c1, T c2, T c3, T c4) { // Homogeneous coordinates. } Point(const Point& v) { v_[0] = v.v_[0]; v_[1] = v.v_[1]; v_[2] = v.v_[2]; } const Point& operator = (const Point& v) { v_[0] = v.v_[0]; v_[1] = v.v_[1]; v_[2] = v.v_[2]; return *this; } const Point& operator + (const Point& v) { v_[0] = v_[0]+ v.v_[0]; v_[1] = v_[1]+ v.v_[1]; v_[2] = v_[2]+ v.v_[2]; return *this; } const Point& operator += (const Point& v) { return this->operator+(v); } const Point& operator - (const Point& v) { v_[0] = v_[0]- v.v_[0]; v_[1] = v_[1]- v.v_[1]; v_[2] = v_[2]- v.v_[2]; return *this; } const Point& operator -= (const Point& v) { return this->operator-(v); } friend std::ostream& operator << <> (std::ostream& , const Point<T>&); friend std::istream& operator >> <> (std::istream& , const Point<T>&); }; template<class T> std::ostream& operator << (std::ostream& os, const Point<T>& v) { os << v.v_[0] << " " << v.v_[1] << " " << v.v_[2]; return os; } template<class T> std::istream& operator >> (std::istream& is, const Point<T>& v) { is >> v.v_[0] >> v.v_[1] >> v.v_[2]; return is; } #endif
- [cgal-discuss] using a Point class from another library, Tomislav Maric, 04/24/2012
- Re: [cgal-discuss] using a Point class from another library, Philipp Moeller, 04/24/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] using a Point class from another library, Tomislav Maric, 04/24/2012
