- To:
- Subject: Re: [cgal-discuss] using a Point class from another library
- Date: Tue, 24 Apr 2012 14:17:30 +0200
Wow, thank you so much!
I will investigate then on writing my own Kernel with the Point type I'm
using.
As for the documentation, I can say that I have a somewhat solid C++
background, since I'm working with OpenFOAM (a computational fluid dynamics
library) for the last 3 years, but:
- it is not using STL (nor the concept-refinement-model, there is no
separation of algorithms from
the data structures, etc)
- iterators to a very low extent since the basic data structure is a library
native kind
of a vector
- templates are used extensively, as well as polymorphism through virtual
functions, and
other "regular" c++ stuff
In its way, it's perfect at what it does, but I do see the advantages of STL
based development..
I just want to say that your documentation is excellent, if I'm getting lost,
its definitely
because of my lack of experience with STL-like codes. When I manage to couple
OpenFOAM with
CGAL I would very much like to contribute a how-to or a tutorial to the
documentation, if anyone
finds this useful...
OpenFOAM is a code which is used by automotive industry (among others) and a
lot of institutes
and universities around the world (I've heard recently that it has taken on
around 40% of the market
share in Computational Fluid Dynamics), but the documentation is
non-existant, and my daily work
is basically made up of a lot of hours spent on reverse engineering the code.
I'm sorry for my long E-mail, but I just wanted to let you know that I think
you should be proud
of both the CGAL project and the documentation you have created! Just my 2
cents. :)
Thank you again for your help!
> ----- Original Message -----
> From: Philipp Moeller
> Sent: 04/24/12 12:08 PM
> To:
> "Tomislav Maric"
> writes:
> > Thank you very much for your advice! :)
> > I have some further questions, regarding the functors.
> > [1] If I will later on run geometrical algorithms on top of the
> > Polyhedron_3 that uses some other Point class, I will need to provide
> > the functors that are required by the geometrical algorithms, right
> > (e.g. convex hull of a polyhedron with my own Point type)? I have read
> > about this for the triangulation class in the attached tutorial, page
> > 41 (pdf), but triangulation provides a basic template for which the
> > needed functors are defined, and as soon as I plug in my Point type
> > there, everything fits. This is probably not possible to generalize to
> > Polyhedron_3, because there are a lot of geometrical algorithms in
> > CGAL runing on polyhedra....
> It is a problem you bump into with Kernels a lot. While some data
> structures pretend to be agnostic to the kernel and simply accept every
> point type the algorithms that work upon them are not and your Point
> almost always ends up being a Kernel member. So the "easiest" way is to
> define your own Kernel with your own Point type.
> > [2] I'm kind of getting lost with concepts and refinements, because
> > they are intertwining (seem to be to me, I'm a complete newb), how can
> > I best find out what requirements need to be satisfied for certain
> > operations with types? Should I implement the requirements provided by
> > the concept closest to what I need? There seem to be multiple
> > solutions to the same type problems.... and I keep getting lost...
> Concepts try to express what is expected from a type in terms of syntax
> and semantic (sometimes also in run-time complexity). A type that
> fulfills all requirements of a concept is a model of that concept.
> A function or class template requires its template arguments to be
> models of a certain concept.
> Refinement is somewhat like inheritance between classes in
> C++. Refinement adds constraints and makes the concept "stronger".
> You should try to be exactly as the concept required by the algorithms
> you are going to use.
> Keep in mind that if a function specifies a return type T it actually
> means that the return type of your model must be implicitly convertible
> to T, not exactly of type T.
> Let us know where we can improve the documentation to make some issues
> clearer.
> > Thanks again!
> > Tomislav
> >> Sent: 04/24/12 10:47 AM
> >> To:
> >> "Tomislav Maric"
> >> writes:
> >> > I have managed to make Polyhedron work with my Point class, but when I
> >> > want to read it from an .off file,
> >> > this function:
> >> > template < class Point> inline
> >> > Point&
> >> > file_scan_vertex( File_scanner_OFF& scanner, Point& p) {
> >> > typedef typename Point::R R;
> >> > typedef typename R::RT RT;
> >> > double x, y, z, w;
> >> > scanner.scan_vertex( x, y, z, w);
> >> > if ( w == 1)
> >> > p = Point( RT(x), RT(y), RT(z));
> >> > else
> >> > p = Point( RT(x), RT(y), RT(z), RT(w));
> >> > return p;
> >> > from the file "File_scanner_OFF.h" expects my point to have a
> >> > constructor with 4 arguments. For a simple
> >> > example Point class that I wrote, I have added this without a problem,
> >> > but if a Point class is coming from another
> >> > library, it is a problem. I cannot change the library Point class.
> >> > What should I do?
> >> > Option 1) Inherit from the Point class of the other library and add a
> >> > dummy constructor, counting on
> >> > implicit casting every time i call a method on the Point to
> >> > cast it up?
> >> > 2) Change the .off File_scanner and adapt it somehow?
> >> The problem is a more complicated. Technically, Polyhedron shouldn't
> >> make any assumptions about the concrete type of Point and use a
> >> Construct_point_3 functor to construct them. This additional functor
> >> would go into the traits as well.
> >> As a workaround, I wouldn't change file_scan_vertex but add an overload
> >> to the CGAL namespace, e.g.
> >> namespace CGAL {
> >> inline
> >> MyPoint&
> >> file_scan_vertex( File_scanner_OFF& scanner, MyPoint& p) {
> >> // do my thing here
> >> to change the behavior. This should work as far as I have looked at
> >> things. If not, I'd prefer method 1.
> >> > I don't need homogeneous coordinate representation of points, so this
> >> > kind of constructor is not necessary..
> >> > Working code is attached.
> >> > Thank you!
> >> > Tomislav
> >> HTH,
> >> Philipp Moeller
> >> GeometryFactory
> >> You are currently subscribed to cgal-discuss.
> >> To unsubscribe or access the archives, go to
> >> https://lists-sop.inria.fr/wws/info/cgal-discuss
- [cgal-discuss] using a Point class from another library, Tomislav Maric, 04/24/2012
- Re: [cgal-discuss] using a Point class from another library, Philipp Moeller, 04/24/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] using a Point class from another library, Tomislav Maric, 04/24/2012
