- To:
- Subject: Re: [cgal-discuss] using a Point class from another library
- Date: Tue, 24 Apr 2012 10:47:46 +0200
"Tomislav Maric"
writes:
> I have managed to make Polyhedron work with my Point class, but when I want
> to read it from an .off file,
> this function:
> template < class Point> inline
> Point&
> file_scan_vertex( File_scanner_OFF& scanner, Point& p) {
> typedef typename Point::R R;
> typedef typename R::RT RT;
> double x, y, z, w;
> scanner.scan_vertex( x, y, z, w);
> if ( w == 1)
> p = Point( RT(x), RT(y), RT(z));
> else
> p = Point( RT(x), RT(y), RT(z), RT(w));
> return p;
> from the file "File_scanner_OFF.h" expects my point to have a constructor
> with 4 arguments. For a simple
> example Point class that I wrote, I have added this without a problem, but
> if a Point class is coming from another
> library, it is a problem. I cannot change the library Point class. What
> should I do?
> Option 1) Inherit from the Point class of the other library and add a dummy
> constructor, counting on
> implicit casting every time i call a method on the Point to cast
> it up?
> 2) Change the .off File_scanner and adapt it somehow?
The problem is a more complicated. Technically, Polyhedron shouldn't
make any assumptions about the concrete type of Point and use a
Construct_point_3 functor to construct them. This additional functor
would go into the traits as well.
As a workaround, I wouldn't change file_scan_vertex but add an overload
to the CGAL namespace, e.g.
namespace CGAL {
inline
MyPoint&
file_scan_vertex( File_scanner_OFF& scanner, MyPoint& p) {
// do my thing here
to change the behavior. This should work as far as I have looked at
things. If not, I'd prefer method 1.
> I don't need homogeneous coordinate representation of points, so this kind
> of constructor is not necessary..
> Working code is attached.
> Thank you!
> Tomislav
HTH,
Philipp Moeller
GeometryFactory
- [cgal-discuss] using a Point class from another library, Tomislav Maric, 04/24/2012
- Re: [cgal-discuss] using a Point class from another library, Philipp Moeller, 04/24/2012
- <Possible follow-up(s)>
- Re: [cgal-discuss] using a Point class from another library, Tomislav Maric, 04/24/2012
