cgal-discuss - Re: [cgal-discuss] using a Point class from another library
  • To:
  • Subject: Re: [cgal-discuss] using a Point class from another library
  • Date: Tue, 24 Apr 2012 11:22:11 +0200
Thank you very much for your advice! :)
I have some further questions, regarding the functors.
[1] If I will later on run geometrical algorithms on top of the Polyhedron_3
that uses some other Point class, I will need to provide the functors that
are required by the geometrical algorithms, right (e.g. convex hull of a
polyhedron with my own Point type)? I have read about this for the
triangulation class in the attached tutorial, page 41 (pdf), but
triangulation provides a basic template for which the needed functors are
defined, and as soon as I plug in my Point type there, everything fits. This
is probably not possible to generalize to Polyhedron_3, because there are a
lot of geometrical algorithms in CGAL runing on polyhedra....
[2] I'm kind of getting lost with concepts and refinements, because they are
intertwining (seem to be to me, I'm a complete newb), how can I best find out
what requirements need to be satisfied for certain operations with types?
Should I implement the requirements provided by the concept closest to what I
need? There seem to be multiple solutions to the same type problems.... and I
keep getting lost...
Thanks again!
Tomislav
> ----- Original Message -----
> From: Philipp Moeller
> Sent: 04/24/12 10:47 AM
> To:
> "Tomislav Maric"
> writes:
> > I have managed to make Polyhedron work with my Point class, but when I
> > want to read it from an .off file,
> > this function:
> > template < class Point> inline
> > Point&
> > file_scan_vertex( File_scanner_OFF& scanner, Point& p) {
> >    typedef typename Point::R R;
> >    typedef typename R::RT    RT;
> >    double x, y, z, w;
> >    scanner.scan_vertex( x, y, z, w);
> >    if ( w == 1)
> >        p = Point( RT(x), RT(y), RT(z));
> >    else
> >        p = Point( RT(x), RT(y), RT(z), RT(w));
> >    return p;
> > from the file "File_scanner_OFF.h" expects my point to have a constructor
> > with 4 arguments. For a simple
> > example Point class that I wrote, I have added this without a problem,
> > but if a Point class is coming from another
> > library, it is a problem. I cannot change the library Point class. What
> > should I do?
> > Option 1) Inherit from the Point class of the other library and add a
> > dummy constructor, counting on
> >          implicit casting every time i call a method on the Point to cast
> > it up?
> >       2) Change the .off File_scanner and adapt it somehow?
> The problem is a more complicated. Technically, Polyhedron shouldn't
> make any assumptions about the concrete type of Point and use a
> Construct_point_3 functor to construct them. This additional functor
> would go into the traits as well.
> As a workaround, I wouldn't change file_scan_vertex but add an overload
> to the CGAL namespace, e.g.
> namespace CGAL {
> inline
> MyPoint&
> file_scan_vertex( File_scanner_OFF& scanner, MyPoint& p) {
>  // do my thing here
> to change the behavior. This should work as far as I have looked at
> things. If not, I'd prefer method 1.
> > I don't need homogeneous coordinate representation of points, so this
> > kind of constructor is not necessary..
> > Working code is attached.
> > Thank you!
> > Tomislav
> HTH,
> Philipp Moeller
> GeometryFactory
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://lists-sop.inria.fr/wws/info/cgal-discuss
Attachment: CGAL_Tutorial.pdf
Description: Attachment: CGAL_Tutorial.pdf
