cgal-discuss - Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • To:
  • Subject: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • Date: Mon, 21 May 2012 21:43:43 +0300
I just checked the environment variables and I have both the CGAL_DIR and the BOOST_ROOT in there :(
On 21 May 2012 21:33, Eugen Funk <> wrote:
to manage environment variables, see this: http://www.windows7hacker.com/index.php/2010/05/how-to-addedit-environment-variables-in-windows-7/
However, I have them too.
It looks like cgal and cgal core are not linked to the boost libs. So the error occurs when a program tries to use them.
I wil investigate the error tomorrow in details and will post the results here.
2012/5/21 Sweety Pie <>
How can I check if they are there on my system too???
On 21 May 2012 21:14, flavio.anjos <> wrote:
On my system I have two macros so that the program works well in the
compilation:
$ BOOST_ROOT = C: \ Program Files (x86) \ boost \ boost_1_44
$ CGAL_DIR = C: \ CGAL-3.9
Before the installation of CGAL, this should be in the windows environment
variables
Best regards
Flávio dos Anjos
View this message in context: http://cgal-discuss.949826.n4.nabble.com/The-program-can-t-start-because-CGAL-vc100-mt-gd-4-0-dll-is-missing-tp4646649p4648554.html
