Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
- To:
- Subject: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
- Date: Mon, 21 May 2012 22:18:23 +0300
Well I have the same versions except the Boost it is 1.47 and am downgrading it now to 1,44. Plus I used CMake to generate the libs of CGAL , will it make any troubles????
On 21 May 2012 22:07, flavio.anjos <> wrote:
In my system is running fine with the versions I mentioned formerly the
boost, CGAL and QT,
Only took me to be able to stop errors when installing ... It should occur
without error in the production of the CGAL libs to work properly ...
Reinstall and see if it has errors. The problem with these macros must be
some mistake in the installation.
View this message in context: http://cgal-discuss.949826.n4.nabble.com/The-program-can-t-start-because-CGAL-vc100-mt-gd-4-0-dll-is-missing-tp4646649p4648652.html
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, (continued)
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/20/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/21/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/21/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Eugen Funk, 05/21/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/22/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Eugen Funk, 05/22/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sweety Pie, 05/23/2012
- Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Sebastien Loriot (GeometryFactory), 05/23/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, Eugen Funk, 05/23/2012
- Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing, flavio.anjos, 05/24/2012
