cgal-discuss - Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • To:
  • Subject: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • Date: Tue, 22 May 2012 00:01:25 +0300
I have reinstalled CGAL and Boost following your recommendations mentioned in the previous posts. When I finish generating the via CMAKe and I open the project called CGAL and try to build all; it gives this error message:
Unable to start program C:\CGAL-3.9\debug\ALL_BUILD. The system cannot find the file specified.
and at the end shows:
========== Build: 6 succeeded, 0 failed, 0 up-to-date, 4 skipped ==========
For both release and debug modes.
On 21 May 2012 22:46, flavio.anjos <> wrote:
I have version 2.8.8 of CMake
use the cmake gui for better installation, check directories and macros
Use the command prompt Qt
View this message in context: http://cgal-discuss.949826.n4.nabble.com/The-program-can-t-start-because-CGAL-vc100-mt-gd-4-0-dll-is-missing-tp4646649p4648736.html
