cgal-discuss - Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • To:
  • Subject: Re: Re: [cgal-discuss] Re: The program can't start because CGAL-vc100-mt-gd-4.0.dll is missing
  • Date: Tue, 22 May 2012 07:42:58 +0200
check your path environment var.
and the created cgalconfig.cmake
the library paths should point to your (cgal-vc100...) libs.
make sure to have compiled cgal in debug mode.
if something is wrong, uninstall all versions of cgal, install yours and run cmake again.
Am 22.05.2012 03:19 schrieb "flavio.anjos" <>:
Well, if you installed everything correctly ... What impresses me is "0
failed" was to have worked ... Really, now do not know what may have caused
it ... Maybe some way of libs placed wrong ... I do not know ... on my
machine:
In Visual Studio in Vc + + directories:
C: \ Program Files x86 \ boost \ boost_1_44
C: \ CGAL-3.9 \ include
C: \ CGAL-3.9 \ auxiliary \ gmp \ include
C: \ CGAL-3.9 \ auxiliary \ taucs \ include
C: \ CGAL-3.9 \ auxiliary \ gdb
compiled in both installation (Debug and Release)before programming...
Now, is not it, really do not know (open a new topic for staff to help you
best regards
Flávio dos Anjos
View this message in context: http://cgal-discuss.949826.n4.nabble.com/The-program-can-t-start-because-CGAL-vc100-mt-gd-4-0-dll-is-missing-tp4646649p4649179.html
