- To:
- Subject: Re: [cgal-discuss] Tetrahedral mesh point location
- Date: Fri, 06 Jul 2012 15:53:21 +0200
On 07/06/2012 03:33 PM, Zohar wrote:
If it's neither a C3T3 nor a Delaunay nor a regular triangulation, there is nothing working out of the box.
Hi,
I have a tetrahedral mesh, and I'd like to perform a point location in it
(find the tet that contains a point). How do I convert my tets to a cgal
structure in order to perform the search?
One cheap solution might be to tweak the AABB_tree.
You define an intersection test predicate for your tetrahedron type
and the point (the test being "is inside tetrahedron") and call
all intersected primitives.
Sebastien.
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Tetrahedral-mesh-point-location-tp4655387.html
- [cgal-discuss] Tetrahedral mesh point location, Zohar, 07/06/2012
- Re: [cgal-discuss] Tetrahedral mesh point location, Sebastien Loriot (GeometryFactory), 07/06/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/06/2012
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Sebastien Loriot (GeometryFactory), 07/06/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/07/2012
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Mariette Yvinec, 07/09/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/09/2012
