- To:
- Subject: [cgal-discuss] Re: Tetrahedral mesh point location
- Date: Sat, 7 Jul 2012 10:43:54 -0700 (PDT)
A new model for AABBPrimitive seems quite straight forward, and there are
examples for it in the doc. On the other hand there are no examples for
writing a new model for AABBTraits, and from a look at AABB_traits.h, it
seems like rewriting half of the AABB tree. In this case, although less
elegant, I think it would be easier just to insert all the tets faces
(triangles) into the AABB tree, find the closest face, and determine which
of the two tets that share it, my point is in.
I am asking again (a question I asked in the past), isn't there a way to
populate a c3t3 structure manually?
Does it have the same limitation of the triangulation class, although I
could at least construct a constrained triangulation class?
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Tetrahedral-mesh-point-location-tp4655387p4655392.html
- [cgal-discuss] Tetrahedral mesh point location, Zohar, 07/06/2012
- Re: [cgal-discuss] Tetrahedral mesh point location, Sebastien Loriot (GeometryFactory), 07/06/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/06/2012
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Sebastien Loriot (GeometryFactory), 07/06/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/07/2012
- Re: [cgal-discuss] Re: Tetrahedral mesh point location, Mariette Yvinec, 07/09/2012
- [cgal-discuss] Re: Tetrahedral mesh point location, Zohar, 07/09/2012
