cgal-discuss - [cgal-discuss] Re: Tetrahedral mesh point location
  • To:
  • Subject: [cgal-discuss] Re: Tetrahedral mesh point location
  • Date: Fri, 6 Jul 2012 07:29:34 -0700 (PDT)
I'm not sure about the type, these are tets from a triangular mesh that were
generated with TetGen.
AABB tree solution sounds excellent, but I'm not sure how to go about it. Is
there some example for a custom type other than a triangle
(AABB_custom_example.cpp converts a custom triangle to cgal's triangle)?
Or did you mean that I would simply check intersection of a tet faces with
the point? But then I would need to intersect the point with at every
triangle twice.
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Tetrahedral-mesh-point-location-tp4655387p4655390.html
