cgal-discuss - [cgal-discuss] Problem with make_mesh_3
  • To:
  • Subject: [cgal-discuss] Problem with make_mesh_3
  • Date: Thu, 19 Jul 2012 03:21:35 -0700 (PDT)
cgal-discuss
ju21
Classic List Threaded
1 message Options
ju21 Reply | Threaded | More
Jul 17, 2012; 2:38pm Problem with make_mesh_3
1 post
This post has NOT been accepted by the mailing list yet.
This post was updated on Jul 17, 2012; 2:39pm.
Hi,
I've a little problem with the function make_mesh_3(). It doesn't work every
time I use it. Here is the generated error :
construct initial points:
8/8 initial point(s) found...
Start scan... end scan. [Bad facets:3] [Bad tets:4]
Refining...
Legende of the following line: (#vertices,#steps,#facets to refine,#tets to
refine)
(21,12,16,24) (166.7 vertices/s)Qt has caught an exception thrown from an
event handler. Throwing
exceptions from an event handler is not supported in Qt. You must
reimplement QApplication::notify() and catch all exceptions there.
terminate called after throwing an instance of 'CGAL::Assertion_exception'
what(): CGAL ERROR: assertion violation!
File:
/net/rnd/src/CGAL-3.6.1/linux-x86_64-gcc-4.1.3/include/CGAL/Mesh_3/Refine_facets_3.h
Line: 126
Explanation: (2.2367 -0.161993 -0 0) is already inserted on surface.
I think that a problem of criteria. I choose this one :
facet_angle = 20, facet_size = 1, facet_distance = 0.5,
cell_radius_edge = 4, cell_size = 1.5
So my question is, how can I choose "better" parameters to make my program
work all the time ? Does the parameters depend on the size of the
polyhedron, the number of vertices etc ?
Thank you.
Julie
« Return to cgal-discuss | 20 views
Powered by Nabble See how NAML generates this page
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-make-mesh-3-tp4655492.html
