- To:
- Subject: [cgal-discuss] Re: Problem with make_mesh_3
- Date: Fri, 20 Jul 2012 02:00:49 -0700 (PDT)
These are include and typedef that I made :
#include <CGAL/Polyhedron_3.h>
#include <CGAL/Polyhedral_mesh_domain_3.h>
#include <CGAL/Triangulation_3.h>
#include <CGAL/Mesh_triangulation_3.h>
#include <CGAL/Mesh_complex_3_in_triangulation_3.h>
#include <CGAL/Mesh_criteria_3.h>
#include <CGAL/make_mesh_3.h>
// Domain
typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
typedef CGAL::Polyhedron_3<K> Polyhedron;
typedef CGAL::Polyhedral_mesh_domain_3<Polyhedron, K> Mesh_domain;
// Conversion from any 3D mesh to Polyhedron_3
typedef CgalPolyhedron<K> PolyH;
// Triangulation
typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
typedef CGAL::Mesh_complex_3_in_triangulation_3
C3t3;
typedef CGAL::Triangulation_3<K> Triangulation;
// Criteria
typedef CGAL::Mesh_criteria_3
Mesh_criteria;
Zohar wrote
> First make sure that you use
I use this one.
Zohar wrote
> Second copy the parameters from the example in the mesh generation doc.
I tried the parameters from the example of the document and I still had the
same problem of assertion violation.
Zohar wrote
> Third make sure that your domain (which you didn't specify) encloses the
> function (radius is squared radius for a sphere).
Concerning the domain it's *CgalPolyhedron* which is a home-made class
inheriting from *Polyhedron_3*. It makes a Polyhedron_3 from any sort of 3D
mesh
The code to tetrahedralize :
// mesh is a given parameter representing a closed 3D mesh
PolyH pol ( mesh ); // mesh is turn into a Polyhedron_3 using
class
CgalPolyhedron (alias PolyH)
Mesh_domain domain( pol );
Mesh_criteria criteria( facet_angle = 30, facet_size = 0.1,
facet_distance
= 0.025
, *cell_radius_edge* = 2, cell_size =
0.1 );
C3t3 c3t3 = CGAL::make_mesh_3<C3t3> ( domain, criteria
no_odt(), no_lloyd()
no_perturb(), no_exude() );
One more thing, is it normal that the parameter *cell_radius_edge_ratio*
doesn't work whereas the parameter *cell_radius_edge* does ? Maybe it's the
same thing
So what do you think about all of this ?
Thanks
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-make-mesh-3-tp4655492p4655498.html
- [cgal-discuss] Problem with make_mesh_3, ju21, 07/19/2012
- [cgal-discuss] Re: Problem with make_mesh_3, Zohar, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Sebastien Loriot (GeometryFactory), 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Mariette Yvinec, 07/26/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/30/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Laurent Rineau (CGAL/GeometryFactory), 07/30/2012
