- To:
- Subject: Re: [cgal-discuss] Re: Problem with make_mesh_3
- Date: Thu, 26 Jul 2012 15:07:43 +0200
On 07/26/2012 12:14 PM, ju21 wrote:
yes, you have a remeshing of the surface while meshing the volume.
Zohar wrote
First make sure that you use
Exact_predicates_inexact_constructions_kernel.
Second copy the parameters from the example in the mesh generation doc.
Third make sure that your domain (which you didn't specify) encloses the
function (radius is squared radius for a sphere).
I finally make it work using parameters of another example. But I saw that
when you generate a mesh with *make_mesh_3()* the original points of the
polyhedron are not necessary present in the mesh generated.
Is it normal ?
Sebastien
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Problem-with-make-mesh-3-tp4655492p4655588.html
- [cgal-discuss] Problem with make_mesh_3, ju21, 07/19/2012
- [cgal-discuss] Re: Problem with make_mesh_3, Zohar, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Sebastien Loriot (GeometryFactory), 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Mariette Yvinec, 07/26/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/30/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Laurent Rineau (CGAL/GeometryFactory), 07/30/2012
