- To:
- Subject: Re: [cgal-discuss] Re: Problem with make_mesh_3
- Date: Thu, 26 Jul 2012 15:13:18 +0200
yes it is normal if you use as domain : CGAL::Polyhedral_mesh_domain_3<Polyhedron> If you want the mesh to respect the sharp features of the input polyhedron you need to use; CGAL::Polyhedral_mesh_domain_with_features_3<IGT> Le 26/07/12 12:14, ju21 a écrit :
Zohar wrote First make sure that you use Exact_predicates_inexact_constructions_kernel. Second copy the parameters from the example in the mesh generation doc. Third make sure that your domain (which you didn't specify) encloses the function (radius is squared radius for a sphere). I finally make it work using parameters of another example. But I saw that when you generate a mesh with *make_mesh_3()* the original points of the polyhedron are not necessary present in the mesh generated. Is it normal ? -- View this message in context: http://cgal-discuss.949826.n4.nabble.com/Problem-with-make-mesh-3-tp4655492p4655588.html Sent from the cgal-discuss mailing list archive at Nabble.com. -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Problem with make_mesh_3, ju21, 07/19/2012
- [cgal-discuss] Re: Problem with make_mesh_3, Zohar, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/20/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Sebastien Loriot (GeometryFactory), 07/26/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Mariette Yvinec, 07/26/2012
- [cgal-discuss] Re: Problem with make_mesh_3, ju21, 07/30/2012
- Re: [cgal-discuss] Re: Problem with make_mesh_3, Laurent Rineau (CGAL/GeometryFactory), 07/30/2012
