cgal-discuss - RE: [cgal-discuss] Re: Error in CGAL bool operation to the OFF files
  • To: <>
  • Subject: RE: [cgal-discuss] Re: Error in CGAL bool operation to the OFF files
  • Date: Sat, 15 Sep 2012 11:44:42 +1200
  • Importance: Normal
Hi Dr. Lu,
Thank you very much for your kindly reply. However, the code still crashes after I corrected the code as you pointed out. Both these two OFF files are generated by CGAL program.
Thanks,
Zhanghong Tang
> Date: Fri, 14 Sep 2012 10:08:33 -0700
> From:
> To:
> Subject: [cgal-discuss] Re: Error in CGAL bool operation to the OFF files
> Hi,
> I have just found one thing on your code. I have replaced:
> readoff(&P2,file1);
> by
> readoff(&P2,file2);
> and I tested your program with hand.off and knot.off files, instead of
> a1.off and a2.off and works fine. I can see a knot thru hand in geomview.
> Regards.
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Error-in-CGAL-bool-operation-to-the-OFF-files-tp4655853p4655854.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
