- To:
- Subject: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
- Date: Sat, 15 Sep 2012 05:27:00 -0700 (PDT)
Hi Dr. Lu,
Thank you very much for your kindly reply. The OFF files are attached.
BTW: could you please also check this item for me?
http://cgal-discuss.949826.n4.nabble.com/How-to-mesh-and-refine-the-domains-defined-by-polyhedrons-td4655857.html
Thanks,
Zhanghong Tang
Date: Sat, 15 Sep 2012 04:20:17 -0700
To: [hidden email]
Subject: Re: Error in CGAL bool operation to the OFF files
Could you attach to e-mail the .off files you are using as input in order to reproduce the problem?
Thanks,
Zhanghong Tang
To: [hidden email]
If you reply to this email, your message will be added to the discussion below:
http://cgal-discuss.949826.n4.nabble.com/Error-in-CGAL-bool-operation-to-the-OFF-files-tp4655853p4655859.html
View this message in context: RE: Error in CGAL bool operation to the OFF files
- [cgal-discuss] Error in CGAL bool operation to the OFF files, tang, 09/14/2012
- [cgal-discuss] Re: Error in CGAL bool operation to the OFF files, JuanLu, 09/14/2012
- RE: [cgal-discuss] Re: Error in CGAL bool operation to the OFF files, Zhanghong Tang, 09/15/2012
- [cgal-discuss] Re: Error in CGAL bool operation to the OFF files, JuanLu, 09/15/2012
- [cgal-discuss] RE: Error in CGAL bool operation to the OFF files, tang, 09/15/2012
- [cgal-discuss] RE: Error in CGAL bool operation to the OFF files, JuanLu, 09/15/2012
- RE: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files, Zhanghong Tang, 09/16/2012
- [cgal-discuss] RE: Error in CGAL bool operation to the OFF files, JuanLu, 09/18/2012
- RE: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files, Zhanghong Tang, 09/18/2012
