cgal-discuss - RE: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
  • To: <>
  • Subject: RE: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
  • Date: Sun, 16 Sep 2012 10:36:43 +1200
  • Importance: Normal
Hi Dr. Lu,
Thank you very much for your kindly reply. The OFF files are generated by CGAL code after some bool operations. Is there any funciton in CGAL package to output polyhedron/OFF file to let it can be used by mesher? Do you have any suggestion to simplify (for example, remove very closed nodes) the output polyhedron?
Thanks,
Zhanghong Tang
> Date: Sat, 15 Sep 2012 08:38:27 -0700
> From:
> To:
> Subject: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
> Hi Tang,
> I could see the source of the problem. You have at least two faces
> (triangles) in a1.off with vertices they are linear combination.
> (a1.off)
> Line 356 defines wrong face --> 3 133 65 106
> Line 448 defines wrong face --> 3 123 133 106
> Vertices 106 and 133 has the same value.
> Line 109 defines vertex 106: -0.045 5.51091e-018 -0.45
> Line 136 defines vertex 133: -0.045 5.51091e-018 -0.45
> The conversion from Polyhedron_3 to Nef_polyhedron (line 53 of your main.cpp
> source code) requires to calculate the normals for each of faces in your
> polyhedron. It's not possible to calculate the normal for the above faces.
> Your program should throw an error message "Error !!!!!" in line 106 of
> polyhedron_3_to_nef_3.h
> Later, the program crash in following assert:
> terminate called after throwing an instance of 'CGAL::Assertion_exception'
> what(): CGAL ERROR: assertion violation!
> Expr: pe_prev->is_border() ||
> !internal::Plane_constructor<Plane>::get_plane(pe_prev->facet(),pe_prev->facet()->plane()).is_degenerate()
> File: ../../dev/CGAL-4.1-beta1/include/CGAL/Nef_3/polyhedron_3_to_nef_3.h
> Line: 252
> These faces in your file define a segment instead of a triangle due to the
> linear combination.
> Regards,
> Juan Luis.
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Error-in-CGAL-bool-operation-to-the-OFF-files-tp4655853p4655861.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
