cgal-discuss - RE: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
  • To: <>
  • Subject: RE: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
  • Date: Tue, 18 Sep 2012 12:34:19 +1200
  • Importance: Normal
Dear Dr. Luis,
Thank you very much for your kindly reply. Could you please help me to modify the code to remove the problematic facets and mesh the domain?
On the other hand, I think we can't simplily remove these facets, by this way, the neighboring triangles don't have common edges. So we should sweep edges of two neighboring triangles to remove the triangles whose area is zero.
Thanks,
Zhanghong Tang
> Date: Mon, 17 Sep 2012 17:22:27 -0700
> From:
> To:
> Subject: [cgal-discuss] RE: Error in CGAL bool operation to the OFF files
> Hi,
> I couldn't find any function in order to simplify polyhedron. The option I
> could find is to create any function by using facet iterator for removing
> problematic faces.
> Regards,
> Juan Luis.
> View this message in context: http://cgal-discuss.949826.n4.nabble.com/Error-in-CGAL-bool-operation-to-the-OFF-files-tp4655853p4655872.html
> Sent from the cgal-discuss mailing list archive at Nabble.com.
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
