- To:
- Subject: Re: [cgal-discuss] Changing a regular triangulation
- Date: Mon, 24 Sep 2012 13:10:19 -0400
Thanks for the quick reply Marriette. I did see the no exuder/perturb
requirement in the documentation, but missed the part that says the
other one. A few followup questions.
1. When I render the regular triangulation either in VTK or .mesh
format, I see pictures like this:
http://cgal-discuss.949826.n4.nabble.com/file/n4331141/Capture.jpg
I think there are others who have asked about this problem in the
forum before (as if it was an orientation problem).
2. After I call refine mesh, I can use:
typedef typename Tr::Finite_vertices_iterator Finite_vertices_iterator;
const Tr& tr_ = c3t3.triangulation();
for( Finite_vertices_iterator vit = tr_.finite_vertices_begin();
vit != tr_.finite_vertices_end(); ++vit)
cout << (*vit) << endl;
and I see 4d output. I am assuming the last number is a weight (most
of them are zeros). Now if I try to access the weight using
vit->weight()
I get a compilation error (vit->point() compiles and works). What am I
missing?
Thanks,
--Ram.
On Mon, Sep 24, 2012 at 12:56 PM, Mariette Yvinec
wrote:
> The weights on the mesh vertices come from two sources
> - the handling of one-dimensional features
> - optimization through the exuder
> If you don't want weights, you have
> - to input no one-dimensional feature or use a Polyhedral_mesh_domain_
> rather than a Polyhedral_mesh_domain_with_features_3
> - and choose no_exude()
> in the optimization options.
> Le 24/09/12 15:02, David Arken a écrit :
> I've 100k+ points, and the make_mesh+refine_mesh function puts weights
> on a few hundred. I tried to give them no_perturb() and no_exude() --
> but it seems it still puts weights on the points (is that a bug?). You
> think computing the Delaunay from scratch is the right way to solve my
> problem?
> I was trying to go thru the list of points, find out the weighted
> points, and was hoping to remove and reinsert them. But the following
> loop does not seem to compile: (Maybe my typedefs dont make sense?)
> // Fix regular triangulation
> typedef CGAL::Exact_predicates_inexact_constructions_kernel K;
> typedef CGAL::Polyhedral_mesh_domain_with_features_3<K> Mesh_domain;
> typedef CGAL::Mesh_polyhedron_3<K>::Type Polyhedron;
> typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr;
> typedef
> CGAL::Mesh_complex_3_in_triangulation_3<Tr,Mesh_domain::Corner_index,Mesh_domain::Curve_segment_index>
> C3t3;
> typedef C3t3::Triangulation Tr;
> ++vit)
> std::cout << (*vit).weight() << std::endl;
> Thanks.
> On Mon, Sep 24, 2012 at 3:42 AM, Olivier Devillers
> wrote:
> Le 9/23/12 5:26 PM, David Arken a écrit :
> What is the fastest way to convert a regular triangulation with
> weights on points to another regular triangulation with all weights
> zero. I hope that this will guarantee that the regular triangulation
> is indeed a delaunay triangulation.
> Thanks,
> compute the Delaunay triangulation of the unweighted points !
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
> Mariette Yvinec
> Geometrica project team
> INRIA Sophia-Antipolis
- [cgal-discuss] Changing a regular triangulation, David Arken, 09/23/2012
- Re: [cgal-discuss] Changing a regular triangulation, Olivier Devillers, 09/24/2012
- Re: [cgal-discuss] Changing a regular triangulation, David Arken, 09/24/2012
- Re: [cgal-discuss] Changing a regular triangulation, Mariette Yvinec, 09/24/2012
- Re: [cgal-discuss] Changing a regular triangulation, Mariette Yvinec, 09/25/2012
- Re: [cgal-discuss] Changing a regular triangulation, David Arken, 09/25/2012
- Re: Re: [cgal-discuss] Changing a regular triangulation, Laurent Rineau (CGAL/GeometryFactory), 09/25/2012
- Re: Re: [cgal-discuss] Changing a regular triangulation, David Arken, 09/26/2012
- Re: [cgal-discuss] Changing a regular triangulation, Monique Teillaud, 09/25/2012
