- To:
- Subject: Re: [cgal-discuss] Changing a regular triangulation
- Date: Tue, 25 Sep 2012 16:41:06 +0200
Usually the cgal mesher has no problem to mesh a cube with or without an accurate representation of the edges .... There might be some problem in the way you input the domain to the mesher ... Le 25/09/12 16:32, David Arken a
écrit :
Can we force the mesher to decompose the convex hull in any way? I think my problem is not orientation but missing tetrahedra on the surface of the cube. On Tue, Sep 25, 2012 at 10:30 AM, Mariette Yvinec <> wrote: The regular triangulation computed always fills the convex hull of it vertices, but the mesher does not consider all the tetrahedra as being part of the mesh : only the tets with their dual (weighted) center point within the cube are considered as part of the mesh and listed by the C3T3. Le 25/09/12 16:24, David Arken a écrit : Thanks for all the help. Another followup question: When I force the weights of a regular triangulation of a cube to be all zeros, the output triangulation I get is not a decomposition of the convex hull. Is this expected or a bug? Thanks, --Ram On Tue, Sep 25, 2012 at 7:19 AM, Mariette Yvinec <> wrote: Le 24/09/12 19:10, David Arken a écrit : Thanks for the quick reply Marriette. I did see the no exuder/perturb requirement in the documentation, but missed the part that says the other one. A few followup questions. 1. When I render the regular triangulation either in VTK or .mesh format, I see pictures like this: http://cgal-discuss.949826.n4.nabble.com/file/n4331141/Capture.jpg I think there are others who have asked about this problem in the forum before (as if it was an orientation problem). One solution to avoid orientation problems is to ask the the viewer to render both sides of each facet. 2. After I call refine mesh, I can use: typedef typename Tr::Finite_vertices_iterator Finite_vertices_iterator; const Tr& tr_ = c3t3.triangulation(); for( Finite_vertices_iterator vit = tr_.finite_vertices_begin(); vit != tr_.finite_vertices_end(); ++vit) cout << (*vit) << endl; and I see 4d output. I am assuming the last number is a weight (most of them are zeros). Now if I try to access the weight using vit->weight() I get a compilation error (vit->point() compiles and works). What am I missing? vit->point().weight() should work better Thanks, --Ram. On Mon, Sep 24, 2012 at 12:56 PM, Mariette Yvinec <> wrote: The weights on the mesh vertices come from two sources - the handling of one-dimensional features - optimization through the exuder If you don't want weights, you have - to input no one-dimensional feature or use a Polyhedral_mesh_domain_ rather than a Polyhedral_mesh_domain_with_features_3 - and choose no_exude() in the optimization options. Le 24/09/12 15:02, David Arken a écrit : I've 100k+ points, and the make_mesh+refine_mesh function puts weights on a few hundred. I tried to give them no_perturb() and no_exude() -- but it seems it still puts weights on the points (is that a bug?). You think computing the Delaunay from scratch is the right way to solve my problem? I was trying to go thru the list of points, find out the weighted points, and was hoping to remove and reinsert them. But the following loop does not seem to compile: (Maybe my typedefs dont make sense?) // Fix regular triangulation typedef CGAL::Exact_predicates_inexact_constructions_kernel K; typedef CGAL::Polyhedral_mesh_domain_with_features_3<K> Mesh_domain; typedef CGAL::Mesh_polyhedron_3<K>::Type Polyhedron; typedef CGAL::Mesh_triangulation_3<Mesh_domain>::type Tr; typedef CGAL::Mesh_complex_3_in_triangulation_3<Tr,Mesh_domain::Corner_index,Mesh_domain::Curve_segment_index> C3t3; typedef C3t3::Triangulation Tr; typedef typename Tr::Finite_vertices_iterator Finite_vertices_iterator; const Tr& tr_ = c3t3.triangulation(); for( Finite_vertices_iterator vit = tr_.finite_vertices_begin(); vit != tr_.finite_vertices_end(); ++vit) std::cout << (*vit).weight() << std::endl; Thanks. On Mon, Sep 24, 2012 at 3:42 AM, Olivier Devillers <> wrote: Le 9/23/12 5:26 PM, David Arken a écrit : What is the fastest way to convert a regular triangulation with weights on points to another regular triangulation with all weights zero. I hope that this will guarantee that the regular triangulation is indeed a delaunay triangulation. Thanks, ???? compute the Delaunay triangulation of the unweighted points ! -- You are currently subscribed to cgal-discuss. To unsubscribe or access the archives, go to https://sympa.inria.fr/sympa/info/cgal-discuss -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis -- Mariette Yvinec Geometrica project team INRIA Sophia-Antipolis |
- [cgal-discuss] Changing a regular triangulation, David Arken, 09/23/2012
- Re: [cgal-discuss] Changing a regular triangulation, Olivier Devillers, 09/24/2012
- Re: [cgal-discuss] Changing a regular triangulation, David Arken, 09/24/2012
- Re: [cgal-discuss] Changing a regular triangulation, Mariette Yvinec, 09/24/2012
- Re: [cgal-discuss] Changing a regular triangulation, Mariette Yvinec, 09/25/2012
- Re: [cgal-discuss] Changing a regular triangulation, David Arken, 09/25/2012
- Re: Re: [cgal-discuss] Changing a regular triangulation, Laurent Rineau (CGAL/GeometryFactory), 09/25/2012
- Re: Re: [cgal-discuss] Changing a regular triangulation, David Arken, 09/26/2012
- Re: [cgal-discuss] Changing a regular triangulation, Monique Teillaud, 09/25/2012
