cgal-discuss - Re: [cgal-discuss] Changing a regular triangulation
  • To:
  • Subject: Re: [cgal-discuss] Changing a regular triangulation
  • Date: Tue, 25 Sep 2012 15:52:51 +0200
Hi,
well, your initial question was only about regular and Delaunay triangulations, so, the answer to this question was not related with C3t3...
best,
Monique Teillaud
Le 24/09/12 21:38, David Arken a écrit :
Hi Olivier,
Do you know why this does not work -- was trying your suggestion:
C3t3 tmp_c3t3; // Code from refine_mesh
std::for_each(c3t3.triangulation().finite_vertices_begin(),
c3t3.triangulation().finite_vertices_end(),
CGAL::details::Insert_vertex_in_c3t3<C3t3>(tmp_c3t3));
c3t3.swap(tmp_c3t3);
// now there are no tetrahedrons in c3t3?
Thanks,
--Ram
On Mon, Sep 24, 2012 at 3:42 AM, Olivier Devillers
wrote:
Le 9/23/12 5:26 PM, David Arken a écrit :
What is the fastest way to convert a regular triangulation with
weights on points to another regular triangulation with all weights
zero. I hope that this will guarantee that the regular triangulation
is indeed a delaunay triangulation.
Thanks,
compute the Delaunay triangulation of the unweighted points !
Monique Teillaud
INRIA Sophia Antipolis - Méditerranée
http://www.inria.fr/sophia/members/Monique.Teillaud/
