cgal-discuss - [cgal-discuss] Surface mesh simplification
  • To:
  • Subject: [cgal-discuss] Surface mesh simplification
  • Date: Tue, 02 Oct 2012 12:36:36 +0200
Le mardi 02 octobre 2012 03:21:59 tang a écrit :
> Dear Dr. Rineau,
> Thank you very much for your so quick reply. I have rebuilt the first two
> project without any anti-virus running, still the same problem, it seems to
> be the bugs of MSVC too.
> Could you please give me some hints on how to simplify mesh by some given
> rules?
> For example:
> 1) area(triangle)<DEPS; or
> 2) length(edge)&lt;EPS
To implement the second criterion, you can use the package "Triangulated
Surface Mesh Simplification" with the Edge_lenght as cost. For the first
criterion, I do not think there is something ready for that in CGAL.
> Polyhedron *obj=(Polyhedron *)object->obj;
> std::ofstream log(filename);
> std::streambuf * oldbuf = std::cout.rdbuf(log.rdbuf());
> std::cout << *obj;
> std::cout.rdbuf( oldbuf);
Note that, to output the polyhedron to the file "filename", you could have
used the "log" stream directly:
log << obj;
instead of manipulating the cout.rdbuf().
Laurent Rineau, PhD
