- To:
- Subject: [cgal-discuss] Re: Surface mesh simplification
- Date: Wed, 3 Oct 2012 01:41:22 -0700 (PDT)
Dear Dr. Rineau,
Thank you very much for your kindly reply. I still want to simplify the
surface mesh.
Since the CGAL can only cope with short edge, I add a short edge to the flat
triangle (2*area(triangle)/max(length)<minlength), and then, I will let the
CGAL to simplify the mesh.
my idea is as follows:
1) add short edge to flag triangles (the function 'splitsmalltriangle');
2) simplify the mesh by removing short edges.
The steps of funciton splitsmalltriangle is as as follows:
for every facet (triangle):
calculate the area of the triangle;
calculate lengths of 3 edges and find the maximal length;
if(any length < minlength) continue;
if(2*area/max(length) > minlength) continue;
get the projection of A (say it to B) on maximal edge, where A is the
opposite vertex of maximal edge;
split the triangle by edge AB;
end
Now I don't know how to split the facet (triangle) by this edge, could you
please give me some hints?
Thanks,
Zhanghong Tang
BTW: the code posted last time has a mistake, it should be like this:
dmax=max(max(d12, d23), d31);
if(area/dmax>edgelengthmin)continue;
/// get the projection of pi to longest edge
if(dmax==d12)
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-when-building-CGAL4-0-2-demo-examples-64-bit-version-tp4655937p4655954.html
- [cgal-discuss] Error when building CGAL4.0.2 + demo + examples (64 bit version), tang, 10/02/2012
- Re: [cgal-discuss] Error when building CGAL4.0.2 + demo + examples (64 bit version), Laurent Rineau (CGAL/GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Error when building CGAL4.0.2 + demo + examples (64 bit version), tang, 10/02/2012
- [cgal-discuss] Surface mesh simplification, Laurent Rineau (CGAL/GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/02/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Sebastien Loriot (GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Laurent Rineau (CGAL/GeometryFactory), 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Philipp Moeller, 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Guillaume Damiand, 10/03/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/04/2012
