- To:
- Subject: Re: [cgal-discuss] Re: Surface mesh simplification
- Date: Wed, 03 Oct 2012 15:54:28 +0200
Dear Tang,
Have a look here
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Polyhedron_ref/Class_Polyhedron_3.html
section Euler Operators (Combinatorial Modifications)
Guillaume
Le 03/10/2012 15:39, tang a écrit :
Dear Dr. Rineau and Loriot,
Could you please help me to take a look at it?
The latest code is below, now I have the facet iterator i and the edge
'splitedge' to be splitted, the new point would be inserted into 'splitedge'
is p, how to split the edge and facet?
Thanks,
Zhanghong Tang
PS: latest code
void splitflattriangle(myobj *object,double edgelengthmin)
/// this function is used to split small triangles height smaller
than the
given threshold
/// a point will be inserted into one edge and the triangle will be
splitted into two
/// Zhanghong Tang @ 10/02/2012
Polyhedron *obj=(Polyhedron *)object->obj;
/// check for small area triangle
Point_3 p1, p2, p3, p;
Line_3 l;
double area, d12, d23, d31, dmax;
Facet_iterator i = obj->facets_begin();
for ( ; i != obj->facets_end(); ++i)
/// get 3 points of this facet(triangle)
Halfedge_handle h = i->halfedge(), splitedge;
/// (p3->p1): h
/// (p1->p2): h->next()
/// (p2->p3): h->next()->next()
p1 = h->vertex()->point();
p2 = h->next()->vertex()->point();
p3 = h->next()->next()->vertex()->point();
Triangle_3 t(p1,p2,p3);
area=2.0*sqrt(CGAL::to_double(t.squared_area ()));
d12=sqrt(CGAL::to_double(CGAL::squared_distance(p1,p2)));
if(d12<=edgelengthmin)continue;
d23=sqrt(CGAL::to_double(CGAL::squared_distance(p2,p3)));
if(d23<=edgelengthmin)continue;
d31=sqrt(CGAL::to_double(CGAL::squared_distance(p3,p1)));
if(d31<=edgelengthmin)continue;
dmax=max(max(d12, d23), d31);
if(area/dmax>edgelengthmin)continue;
/// get the projection of pi to longest edge
if(dmax==d12)
l=Line_3(p1,p2);
p=l.projection(p3);
splitedge = h->next(); /// h->next() will be
splitted by p
else if(dmax==d23)
l=Line_3(p2,p3);
p=l.projection(p1);
splitedge = h->next()->next(); /// h->next()->next()
will be splitted by
p
else
l=Line_3(p3,p1);
p=l.projection(p2);
splitedge = h; /// h will be splitted by p
/// now I have the facet iterator i and the edge 'splitedge' to be
splitted,
/// the new point would be inserted into 'splitedge' is p, how to
split the
/// edge and facet?
/// after split the edge and facet, we reset the iterator to the
beginning
of facet list
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-when-building-CGAL4-0-2-demo-examples-64-bit-version-tp4655937p4655956.html
Guillaume DAMIAND
CNRS, LIRIS UMR 5205
Université Claude Bernard
Bâtiment Nautibus (710)
43 Boulevard du 11 Novembre 1918
69622 Villeurbanne Cedex (France)
Phone: +33 (0)4.72.43.26.62 Fax: +33 (0)4.72.43.15.36
Mail:
- [cgal-discuss] Re: Error when building CGAL4.0.2 + demo + examples (64 bit version), (continued)
- [cgal-discuss] Re: Error when building CGAL4.0.2 + demo + examples (64 bit version), tang, 10/02/2012
- [cgal-discuss] Surface mesh simplification, Laurent Rineau (CGAL/GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/02/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Sebastien Loriot (GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Laurent Rineau (CGAL/GeometryFactory), 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Philipp Moeller, 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Guillaume Damiand, 10/03/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/04/2012
