- To:
- Subject: [cgal-discuss] Re: Surface mesh simplification
- Date: Tue, 2 Oct 2012 05:26:08 -0700 (PDT)
Dear Dr. Rineau,
Thank you very much for your so good 'easy' method to output OFF file. I
test it and it works well.
I have read the link you given several times, however, I still have no idea
on how to simplify the polyhedron, could you please give me some example
code to simplify it, suppose I have the object bellow:
myobj *object;
/// here I extract the 'obj' from object->obj
Polyhedron *obj=(Polyhedron *)object->obj;
/// how to simplify the surface mesh defined in obj according to the rule
length(edge)<EPS?
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Error-when-building-CGAL4-0-2-demo-examples-64-bit-version-tp4655937p4655946.html
- [cgal-discuss] Error when building CGAL4.0.2 + demo + examples (64 bit version), tang, 10/02/2012
- Re: [cgal-discuss] Error when building CGAL4.0.2 + demo + examples (64 bit version), Laurent Rineau (CGAL/GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Error when building CGAL4.0.2 + demo + examples (64 bit version), tang, 10/02/2012
- [cgal-discuss] Surface mesh simplification, Laurent Rineau (CGAL/GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/02/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Sebastien Loriot (GeometryFactory), 10/02/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Laurent Rineau (CGAL/GeometryFactory), 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Philipp Moeller, 10/03/2012
- Re: [cgal-discuss] Re: Surface mesh simplification, Guillaume Damiand, 10/03/2012
- [cgal-discuss] Re: Surface mesh simplification, tang, 10/04/2012
