cgal-discuss - [cgal-discuss] Re: Installation issues
  • To:
  • Subject: [cgal-discuss] Re: Installation issues
  • Date: Thu, 11 Oct 2012 10:00:10 -0700 (PDT)
I'm not sure why you ask, but - the same thing: [I suppose if I had a
standard MinGW installed also, that would have kicked in, but I can't use
that, I specifically have to use the RTools-MinGW chain so that I can fully
interface with R]
CMake Error: CMake was unable to find a build program corresponding to
"MinGW Makefiles". CMAKE_MAKE_PROGRAM is not set. You probably need to
select a different build tool.
CMake Error: Error required internal CMake variable not set, cmake may be
not be built correctly.
Missing variable is:
CMAKE_CXX_COMPILER_ENV_VAR
CMake Error: Could not find cmake module file:C:/Program Files
(x86)/CGAL-4.0.2/CMakeFiles/CMakeCXXCompiler.cmake
Configuring incomplete, errors occurred!
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Installation-issues-tp4656010p4656031.html
