- To: <>
- Subject: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
- Date: Tue, 23 Oct 2012 18:51:49 -0500
I have a program that uses Nef_Polyhedron_3 to merge several disjoint structured grids, and then remeshes the surface using a delaunay triangulation. Out of several surfaces I'm preparing, one has stubbornly refused to mesh. After a day or so of tweaking the parameters, I generated .off files to permit me to visualize the intermediate surface and troubleshoot.
In examining the .off version of the troublesome surface, I noticed that there are several degenerate triangles (e.g., 2 coincident vertices, and therefore a zero-valued normal). I'm assuming this has to do with distances in the EPECK kernel that are too small to represent in the EPICK kernel, which therefore get rounded off.
My question is this: does a filter exist which can remove these triangles *prior* to casting the polyhedron to an EPICK kernel? Or am I on my own (e.g., either filtering the inexact kernel version and simply erasing the degenerate triangles, or alternately, filtering the exact one and merging any triangle with a sufficiently high aspect ratio with an adjacent triangle in the hopes of avoiding degeneracy post-cast)?
Any help would be very much appreciated.
-Richard
- [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/24/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Richard Downe, 10/25/2012
- Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3, Sebastien Loriot (GeometryFactory), 10/25/2012
