cgal-discuss - Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
  • To:
  • Subject: Re: [cgal-discuss] degenerate triangles in output of Nef_Polyhedron_3
  • Date: Wed, 24 Oct 2012 09:16:49 +0200
You can try using the edge simplification algorithm [1]
There is an example given in this thread (second post) [2]
Let us know if this does not solve the problem.
Sebastien.
[1] http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Surface_mesh_simplification/Chapter_main.html
[2] http://cgal-discuss.949826.n4.nabble.com/understanding-edge-collapse-tt3248855.html
On 10/24/2012 01:51 AM, Richard Downe wrote:
I have a program that uses Nef_Polyhedron_3 to merge several disjoint
structured grids, and then remeshes the surface using a delaunay
triangulation. Out of several surfaces I'm preparing, one has stubbornly
refused to mesh. After a day or so of tweaking the parameters, I
generated .off files to permit me to visualize the intermediate surface
and troubleshoot.
In examining the .off version of the troublesome surface, I noticed that
there are several degenerate triangles (e.g., 2 coincident vertices, and
therefore a zero-valued normal). I'm assuming this has to do with
distances in the EPECK kernel that are too small to represent in the
EPICK kernel, which therefore get rounded off.
My question is this: does a filter exist which can remove these
triangles *prior* to casting the polyhedron to an EPICK kernel? Or am I
on my own (e.g., either filtering the inexact kernel version and simply
erasing the degenerate triangles, or alternately, filtering the exact
one and merging any triangle with a sufficiently high aspect ratio with
an adjacent triangle in the hopes of avoiding degeneracy post-cast)?
Any help would be very much appreciated.
-Richard
