- To:
- Subject: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler
- Date: Tue, 20 Nov 2012 21:13:01 +0000
I've been using CGAL 4.1 for a while with gcc 4.7 without problems.
I've just upgraded to CGAL 4.1 (from 4.0.2) on a machine that has
Intel compilers installed. icpc -v gives:
icpc version 12.1.4 (gcc version 4.4.6 compatibility))
I now get a load of compiler errors from the file
CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h:
CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h(206): error:
destructible entities are not allowed inside of a statement expression
return CGAL_OR( (do_axis_intersect_aux<K,AXE,SIDE>(p_min.y()-j->y(),
p_min.z()-j->z(), sides) <= 0),
Any suggestions on how to work around this?
Garth
- [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Garth N. Wells, 11/20/2012
- Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Laurent Rineau (CGAL/GeometryFactory), 11/20/2012
- Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Garth N. Wells, 11/20/2012
- Re: Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Laurent Rineau (CGAL/GeometryFactory), 11/21/2012
