cgal-discuss - Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler
  • To:
  • Subject: Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler
  • Date: Tue, 20 Nov 2012 22:41:04 +0100
Le mardi 20 novembre 2012 21:13:01 Garth N. Wells a écrit :
> I've been using CGAL 4.1 for a while with gcc 4.7 without problems.
> I've just upgraded to CGAL 4.1 (from 4.0.2) on a machine that has
> Intel compilers installed. icpc -v gives:
> icpc version 12.1.4 (gcc version 4.4.6 compatibility))
> I now get a load of compiler errors from the file
> CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h:
> CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h(206): error:
> destructible entities are not allowed inside of a statement expression
> return CGAL_OR( (do_axis_intersect_aux<K,AXE,SIDE>(p_min.y()-j->y(),
> p_min.z()-j->z(), sides) <= 0),
> Any suggestions on how to work around this?
Which compiler flags have you used?
Laurent Rineau, PhD
