cgal-discuss - Re: Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler
  • To:
  • Subject: Re: Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler
  • Date: Wed, 21 Nov 2012 09:06:41 +0100
Le mardi 20 novembre 2012 22:35:41 Garth N. Wells a écrit :
> On Tue, Nov 20, 2012 at 9:41 PM, Laurent Rineau (CGAL/GeometryFactory)
> wrote:
> > Le mardi 20 novembre 2012 21:13:01 Garth N. Wells a écrit :
> >> I've been using CGAL 4.1 for a while with gcc 4.7 without problems.
> >> I've just upgraded to CGAL 4.1 (from 4.0.2) on a machine that has
> >> Intel compilers installed. icpc -v gives:
> >> icpc version 12.1.4 (gcc version 4.4.6 compatibility))
> >> I now get a load of compiler errors from the file
> >> CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h:
> >> CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h(206):
> >> error:
> >> destructible entities are not allowed inside of a statement expression
> >> return CGAL_OR(
> >> (do_axis_intersect_aux<K,AXE,SIDE>(p_min.y()-j->y(),
> >> p_min.z()-j->z(), sides) <= 0),
> >> Any suggestions on how to work around this?
> > Which compiler flags have you used?
> -fp-model strict -openmp -O3 -xHost
There are other flags, such as several -I.
My guess is that you are using the Intel compiler with the the
<CGAL/compiler_config.h> that was generated during the compilation of CGAL
libraries with g++. Please rebuild your CGAL libraries with that the Intel
Compiler. icpc version 12.1 should be supported. It is in the set of tested
compilers in the CGAL daily tests suite.
Laurent Rineau, PhD
