- To:
- Subject: Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler
- Date: Tue, 20 Nov 2012 22:35:41 +0000
On Tue, Nov 20, 2012 at 9:41 PM, Laurent Rineau (CGAL/GeometryFactory)
wrote:
> Le mardi 20 novembre 2012 21:13:01 Garth N. Wells a écrit :
>> I've been using CGAL 4.1 for a while with gcc 4.7 without problems.
>> I've just upgraded to CGAL 4.1 (from 4.0.2) on a machine that has
>> Intel compilers installed. icpc -v gives:
>> icpc version 12.1.4 (gcc version 4.4.6 compatibility))
>> I now get a load of compiler errors from the file
>> CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h:
>> CGAL/internal/Intersections_3/Bbox_3_Triangle_3_do_intersect.h(206): error:
>> destructible entities are not allowed inside of a statement expression
>> return CGAL_OR(
>> (do_axis_intersect_aux<K,AXE,SIDE>(p_min.y()-j->y(),
>> p_min.z()-j->z(), sides) <= 0),
>> Any suggestions on how to work around this?
> Which compiler flags have you used?
-fp-model strict -openmp -O3 -xHost
Garth
> Laurent Rineau, PhD
> R&D Engineer at GeometryFactory http://www.geometryfactory.com/
> Release Manager of the CGAL Project http://www.cgal.org/
> You are currently subscribed to cgal-discuss.
> To unsubscribe or access the archives, go to
> https://sympa.inria.fr/sympa/info/cgal-discuss
- [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Garth N. Wells, 11/20/2012
- Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Laurent Rineau (CGAL/GeometryFactory), 11/20/2012
- Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Garth N. Wells, 11/20/2012
- Re: Re: [cgal-discuss] CGAL 4.1 compile errors with Intel C++ compiler, Laurent Rineau (CGAL/GeometryFactory), 11/21/2012
