- To: "" <>
- Subject: [cgal-discuss] use CGAL as the grid generator
- Date: Sat, 5 Jan 2013 09:25:01 +0800 (CST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.cn; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:Message-ID:Date:From:Reply-To:Subject:To:MIME-Version:Content-Type; b=tj76wTgfYLeIMXnDxjtX/VA9SeemJB+i6K6SZIUIeAykn+h2B2Da3wZ9o13prrF05unCNfNIy3vSp+nVPv4Hcw9bJTy5VlbHOs0a1BSYyBoAgp2bRyNW+br2yw0hjNSRPXGtOUZ6oobc6eKmYQHSsci0bCHaSAGyB+3PvTvg6Bo=;
Dear friends:
I want to develop a numerical simulation package for convection heattransfer in 2-D domain with finite volume method. I want to use CGAL as thegrid generator. The computational domain is composed of by line , arc , etc.
Could you please tell me which package of CGAL should i started from.
I just installed it successfully in opensuse 12.1.
Regards
- [cgal-discuss] use CGAL as the grid generator, ztdep, 01/05/2013
- Re: [cgal-discuss] use CGAL as the grid generator, Sebastien Loriot (GeometryFactory), 01/07/2013
- 回复: [cgal-discuss] use CGAL as the grid generator, ztdep, 01/07/2013
- Re: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
- Re: 回复: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
- 回复: 回复: [cgal-discuss] use CGAL as the grid generator, ztdep, 01/07/2013
- Re: 回复: 回复: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
