cgal-discuss - 回复: [cgal-discuss] use CGAL as the grid generator
  • To: "" <>
  • Subject: 回复: [cgal-discuss] use CGAL as the grid generator
  • Date: Mon, 7 Jan 2013 18:13:19 +0800 (CST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.cn; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=h9RTGt5J0BulzlgcOXNHz0XMTOjHZJ7zCKmgDetnDg4FZXx9gdK17UYB6dOfQDGO6HGx/dGZvBIvIXf6e/GIyEkINJy4TwzM5Q4fNMFNI+el4wTEsXjR97ejiE7azQGmD4cjBYdt8pnsBOB2MqhlQh87XHBVT/mKrTUK6GM4B2k=;
Dear Lauren Rineau:
    thank you very much for you feedback. I am reading the tutorial for 2D mesh. But it seems
in the tutorial ,  polygon package was not used. only some points were set. Could you please give me
some more information about generation mesh in a polygon region
regards
发件人: Laurent Rineau (CGAL/GeometryFactory) <>
收件人:
发送日期: 2013年1月7日, 星期一, 5:01 下午
主题: Re: [cgal-discuss] use CGAL as the grid generator
Le samedi 05 janvier 2013 09:25:01 a 閏rit :
> Dear friends:  I want to develop a numerical simulation package for
> convection heat transfer in 2-D domain with finite volume method. I want
> to  use CGAL as the grid generator. The computational domain is composed of
> by line , arc , etc. Could you please tell me which package of CGAL should
> i started from. I just installed it successfully in opensuse 12.1.
For 2D domain, the only meshing tool that CGAL has is the 2D Mesh Generator
(Mesh_2), that is documented here:
  http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2/Chapter_main.html
That creates a triangular mesh of a domain defined by an arrangement of
polygons or polygonal lines.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory          http://www.geometryfactory.com/
Release Manager of the CGAL Project      http://www.cgal.org/
