- To: "" <>
- Subject: 回复: 回复: [cgal-discuss] use CGAL as the grid generator
- Date: Mon, 7 Jan 2013 20:13:36 +0800 (CST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com.cn; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=noyuxUddVgXqSahhGVJn6Ec2MTxV0GqAWr+HEevyT9XBPeXtQwX/851NYiDeXLmfKYEa3bwdDvR8HpK+4jY7+gb9G/QX4bHbjhbUi+1f+jk7UInFe4RHs/p2Ojc1yzkqHgHiq8KaCpMtEGnz0GAe3RnEqPw+rdBWtgTo8xgEh28=;
Dear Lauren Rineau:
Insert segments one by one can only be used for simple geometry, if i treate with a complex region, like the one on the CGAL manual page
http://www.cgal.org/Manual/latest/doc_html/cgal_manual/Mesh_2/delaunaymesh-teaser.png
, how to input the boundary into cgal.
regards
发件人: Laurent Rineau (CGAL/GeometryFactory) <>
收件人:
发送日期: 2013年1月7日, 星期一, 6:19 下午
主题: Re: 回复: [cgal-discuss] use CGAL as the grid generator
Le lundi 07 janvier 2013 18:13:19 a 閏rit :
> Dear Lauren Rineau:
> thank you very much for you feedback. I am reading the tutorial for 2D
> mesh. But it seems in the tutorial , polygon package was not used. only
> some points were set. Could you please give me some more information about
> generation mesh in a polygon region
The 2D Mesh Generation package deals with segment constraints. But you can
insert the edges of a polygon one by one in the constrained Delaunay
triangulation, and the result will be a mesh of the interior of the polygon.
Laurent Rineau, PhD
- [cgal-discuss] use CGAL as the grid generator, ztdep, 01/05/2013
- Re: [cgal-discuss] use CGAL as the grid generator, Sebastien Loriot (GeometryFactory), 01/07/2013
- 回复: [cgal-discuss] use CGAL as the grid generator, ztdep, 01/07/2013
- Re: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
- Re: 回复: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
- 回复: 回复: [cgal-discuss] use CGAL as the grid generator, ztdep, 01/07/2013
- Re: 回复: 回复: [cgal-discuss] use CGAL as the grid generator, Laurent Rineau (CGAL/GeometryFactory), 01/07/2013
