- To:
- Subject: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
- Date: Thu, 24 Jan 2013 05:18:52 +0100
If in cmake you set CMAKE_INSTALL_PREFIX to C:/Program Files/CGAL
you should have in C:/Program Files/CGAL/lib
CGAL_Core-vc100-mt-4.0.lib and CGAL_Core-vc100-mt-gd-4.0.lib
If you have only one of the two, then it means you compiled CGAL
only in release or debug mode. The compilation mode must be chosen
in Visual studio as you can see on the attached screenshot.
Sebastien.
Description: PNG image
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', (continued)
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/24/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/24/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/24/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Andreas Fabri, 01/24/2013
