cgal-discuss - Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
  • To: "" <>
  • Subject: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
  • Date: Wed, 23 Jan 2013 13:10:51 -0800 (PST)
  • Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=OSxzW+AZGQU3omRnHZccOAnnvvTKhq+wwpeTEDAvHl9VDLt+wFGLvSBIGwAfw1r21IMSGE12arThasDygGNBga/9udJb2hixEX6pzGkVRU7N0AN0j4uv0o0u1B0u9ozzw4tM0hIta+Vjffl9thTueiguSvahq5XF/iK5VcA1HSU=;
Hi ,
I have some folder bin,src, include,config, x64 .
I have ALL_BUILD.vcxproj ,
ALL_BUILD.vcxproj.filters ,
ALL_BUILD.vcxproj.user ,
INSTALL.vcxproj ,
INSTALL.vcxproj.filters ,
INSTALL.vcxproj.user ,
install_FindCGAL.vcxproj ,
install_FindCGAL.vcxproj.filters ,
install_FindCGAL.vcxproj.user ,
ZERO_CHECK.vcxproj ,
ZERO_CHECK.vcxproj.filters ,
ZERO_CHECK.vcxproj.user ,
cmake_install.cmake ,
CGALConfig.cmake ,
CGAL.suo ,
CGAL.sdf
CGAL.sln
but in .sln format I have CGAL.sln only .
I open ALL_Build.vcxproj and it reaches the error :
unable to start program   C\CGAL4-0\build\*64\Release \ALL-Build
the system can not found the file specified .
Wich one I should open and wich one I should set as start up project ?
Thanks a lot for your help
To:
Sent: Wednesday, January 23, 2013 12:54 PM
Subject: RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
Hi,
Can you show the contents of the folder where you say you are building CGAL into? Is there a all_build file? If yes, then you need to open tht in visual studio and compile it in debug mode and release mode.
Just be sure to use the same compiler for visual studio i mean for e.g.  VC10 throughout when configuring cgal, and also building. And also for all its external libraries.
Regards
Mihir.
Sent: 23 January 2013 21:50
To:
Hi Mihir ,
My problem is I dont know what I should do after using CMake for configure and generate CGAL library . I usually open CGAL.sln file created by cmake certainly in relase mode . Ihave checked it in CMake gui .
 CMAKE_build_type                                         Release
CMAKE_INSTALL_PREFIX    C:/Program Files/CGAL
then when I open CGAL.sln I set the release mode in visuall studio.
and then High light Install as start up project and then press the start debugging (F5)
after some processing I see the output  :
Build succeeded.
6>
6>Time Elapsed 00:00:00.10
7>------ Skipped Build: Project: INSTALL, Configuration: Release x64 ------
7>Project not selected to build for this solution configuration
========== Build: 6 succeeded, 0 failed, 0 up-to-date, 1 skipped ==========
and this finish with a dialog box that say  :
unable to start program   C\CGAL4-0\build\*64\Release \install
I have tried it by setting CGAL as start up but it reaches the error about not founding the CGAL-vc100-mt-gd-4.0.lib .
I am using CGAL -manual .
To:
Sent: Wednesday, January 23, 2013 12:23 PM
Hi,
the very meaning, that you are getting such a message means tht cgal is not completely installed on your machine. go through the documentation, very carefully. i my self had to install it thrice before, i could use it. this by no means implies the cgal sucks. its might just be a little complicated to install.
can you please list in detail what all you are doing to install cgal?
regards
mihir.
On 23 January 2013 13:07, sara ershadi <> wrote:
Hi ,
I have configure and generayte CGAL library with CMAke then I open CGAL.sln in created build folder then . I set CGAL as start up project and then press the button for debug . It seems the error about not founding the
> 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
then I set others as start up . they reaches to the same error .  It has not any difference in debug or release mode I have tried a lot and the result error is the same :
I have tried to run examples of CGAL too. after I configure AABB-tree truly configure and generate with CMake 2.8.9 . and open the .sln file it reaches to the same error in debug or release mode .
Thanks
Sara
To: "" <>
Sent: Wednesday, January 23, 2013 3:35 PM
Subject: Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
Hi Laurent and Sebastien ,
Thanks
Sara
To:
Sent: Wednesday, January 23, 2013 3:11 PM
Le mercredi 23 janvier 2013 03:27:41 sara ershadi a écrit :
> Hi ,
> This is the error :
That error cannot be displayed when you are compiling the CGAL library itself.
After the CMake configuration of the CGAL libraries, a solution named
"CGAL.sln". Build that solution in Relase mode *and* in Debug mode. That will
solve your problem.
Laurent Rineau, PhD
R&D Engineer at GeometryFactory          http://www.geometryfactory.com/
Release Manager of the CGAL Project      http://www.cgal.org/
Best Regards
Mihir
