- To: "" <>
- Subject: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
- Date: Wed, 23 Jan 2013 12:49:58 -0800 (PST)
- Domainkey-signature: a=rsa-sha1; q=dns; c=nofws; s=s1024; d=yahoo.com; h=X-YMail-OSG:Received:X-Rocket-MIMEInfo:X-Mailer:References:Message-ID:Date:From:Reply-To:Subject:To:In-Reply-To:MIME-Version:Content-Type; b=Ips8tec5LC/v3XnO+YKBNCvthHSKUDCMEDgI+qKiIO1Y51hNiJZxTuWYPP7wGLB1CsU1A5CuCTEYK7FGWoTrkfOs+w7wtryoRV8JnbQCsvtnpI7mxYEmyBdKhzi8fPBOKlHw/O854CLCN8wvH1GxceBfRZ1k7lkhfWoN+e0OhrE=;
Hi Mihir ,
My problem is I dont know what I should do after using CMake for configure and generate CGAL library . I usually open CGAL.sln file created by cmake certainly in relase mode . Ihave checked it in CMake gui .
CMAKE_build_type Release
CMAKE_INSTALL_PREFIX C:/Program Files/CGAL
then when I open CGAL.sln I set the release mode in visuall studio.
and then High light Install as start up project and then press the start debugging (F5)
after some processing I see the output :
Build succeeded.
6>
6>Time Elapsed 00:00:00.10
7>------ Skipped Build: Project: INSTALL, Configuration: Release x64 ------
7>Project not selected to build for this solution configuration
========== Build: 6 succeeded, 0 failed, 0 up-to-date, 1 skipped ==========
and this finish with a dialog box that say :
unable to start program C\CGAL4-0\build\*64\Release \installthe system can not found the file specified .
I have tried it by setting CGAL as start up but it reaches the error about not founding the CGAL-vc100-mt-gd-4.0.lib .
I am using CGAL -manual .Thanks a lot for your help
To:
Sent: Wednesday, January 23, 2013 12:23 PM
Hi,
the very meaning, that you are getting such a message means tht cgal is not completely installed on your machine. go through the documentation, very carefully. i my self had to install it thrice before, i could use it. this by no means implies the cgal sucks. its might just be a little complicated to install.
can you please list in detail what all you are doing to install cgal?
regards
mihir.
Best Regards
Mihir
regards
mihir.
On 23 January 2013 13:07, sara ershadi <> wrote:
Hi ,I have configure and generayte CGAL library with CMAke then I open CGAL.sln in created build folder then . I set CGAL as start up project and then press the button for debug . It seems the error about not founding the> 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
then I set others as start up . they reaches to the same error . It has not any difference in debug or release mode I have tried a lot and the result error is the same :> 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
I have tried to run examples of CGAL too. after I configure AABB-tree truly configure and generate with CMake 2.8.9 . and open the .sln file it reaches to the same error in debug or release mode .ThanksSara
Subject: Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
Hi Laurent and Sebastien ,
ThanksSara
To:
Sent: Wednesday, January 23, 2013 3:11 PM
Le mercredi 23 janvier 2013 03:27:41 sara ershadi a écrit :
> Hi ,
> This is the error :
That error cannot be displayed when you are compiling the CGAL library itself.
After the CMake configuration of the CGAL libraries, a solution named
"CGAL.sln". Build that solution in Relase mode *and* in Debug mode. That will
solve your problem.
Laurent Rineau, PhD
Best Regards
Mihir
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/24/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/24/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/24/2013
