- To: <>
- Subject: RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib'
- Date: Wed, 23 Jan 2013 21:54:44 +0100
Hi,
Can you show the contents of the folder where you say you are building CGAL into? Is there a all_build file? If yes, then you need to open tht in visual studio and compile it in debug mode and release mode. Just be sure to use the same compiler for visual studio i mean for e.g. VC10 throughout when configuring cgal, and also building. And also for all its external libraries.
Regards Mihir.
Hi Mihir ,
My problem is I dont know what I should do after using CMake for configure and generate CGAL library . I usually open CGAL.sln file created by cmake certainly in relase mode . Ihave checked it in CMake gui . CMAKE_build_type Release CMAKE_INSTALL_PREFIX C:/Program Files/CGAL
then when I open CGAL.sln I set the release mode in visuall studio. and then High light Install as start up project and then press the start debugging (F5) after some processing I see the output :
Build succeeded. 6> 6>Time Elapsed 00:00:00.10 7>------ Skipped Build: Project: INSTALL, Configuration: Release x64 ------ 7>Project not selected to build for this solution configuration ========== Build: 6 succeeded, 0 failed, 0 up-to-date, 1 skipped ==========
and this finish with a dialog box that say : unable to start program C\CGAL4-0\build\*64\Release \install the system can not found the file specified .
I have tried it by setting CGAL as start up but it reaches the error about not founding the CGAL-vc100-mt-gd-4.0.lib . I am using CGAL -manual .
Thanks a lot for your help
Hi, On 23 January 2013 13:07, sara ershadi <> wrote: Hi ,
I have configure and generayte CGAL library with CMAke then I open CGAL.sln in created build folder then . I set CGAL as start up project and then press the button for debug . It seems the error about not founding the > 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib' then I set others as start up . they reaches to the same error . It has not any difference in debug or release mode I have tried a lot and the result error is the same : > 2>LINK : fatal error LNK1104: cannot open file 'CGAL-vc100-mt-gd-4.0.lib'
I have tried to run examples of CGAL too. after I configure AABB-tree truly configure and generate with CMake 2.8.9 . and open the .sln file it reaches to the same error in debug or release mode .
Thanks Sara
Hi Laurent and Sebastien ,
Thanks Sara
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', (continued)
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/23/2013
- Re: Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- RE: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Mihir Joshi, 01/23/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Sebastien Loriot (GeometryFactory), 01/24/2013
- Re: Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Laurent Rineau (CGAL/GeometryFactory), 01/24/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', sara ershadi, 01/24/2013
- Re: [cgal-discuss] 'CGAL-vc100-mt-gd-4.0.lib', Andreas Fabri, 01/24/2013
