- To:
- Subject: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3
- Date: Mon, 18 Feb 2013 06:16:47 -0800 (PST)
Thank you for your answer!
Actually I'm kind of confused because I didn't made the normal_cycle.h file,
and it is supposed to work without any modification: it has already been
used before and everything worked well, I was asked to do my own Extended
Polyhedron class in order to be able to use normal_cycle.h, that I wasn't
suppose to edit.
However I changed the std::for_each line and there is no more problem here.
I also made a modification in normal_cycle.h for the "typename" error and I
think this will be okay for now.
But I still don't know what to do about the AreaFacetTriangle problem.
I have:
/template <class _Poly>
class Normal_cycle
typedef _Poly Polyhedron;
typedef typename Polyhedron::Halfedge_data_structure HDS;
typedef typename Polyhedron::Vertex Vertex;
typedef typename Polyhedron::Halfedge Halfedge;
typedef typename Polyhedron::Facet Facet;
typedef typename Polyhedron::Vertex_handle Vertex_handle;
typedef typename Polyhedron::Halfedge_handle Halfedge_handle;
typedef typename Polyhedron::Facet_handle Facet_handle;
typedef typename Polyhedron::Vertex_iterator Vertex_iterator;
typedef typename Polyhedron::Halfedge_iterator Halfedge_iterator;
typedef typename Polyhedron::Edge_iterator Edge_iterator;
typedef typename Polyhedron::Facet_iterator Facet_iterator;
typedef typename Polyhedron::Halfedge_around_facet_circulator
Halfedge_around_facet_circulator;
typedef typename Polyhedron::Halfedge_around_vertex_circulator
Halfedge_around_vertex_circulator;
typedef typename Polyhedron::Point_3 Point;
typedef typename Polyhedron::FT FT;
typedef typename Polyhedron::Vector Vector;
void principal_curvature_per_vert(Vertex pVertex,
double ppMatrix_sum[3][3])
Halfedge_around_vertex_circulator pHalfedge = pVertex.vertex_begin();
Halfedge_around_vertex_circulator pHalfedgeStart = pHalfedge;
area+=AreaFacetTriangle(pHalfedge->facet());
double AreaFacetTriangle(Facet_handle &f)
Halfedge_around_facet_circulator pHalfedge = f->facet_begin();
I tried to change the parameters to pointers (/double
AreaFacetTriangle(Facet_handle* f)/)
Then I had no more conversion problem, but:
/normal_cycle.h:345:63: erreur:
‘Normal_cycle<ExtendedPolyhedron<CGAL::Simple_cartesian<float>,
ExtendedItems> >::Facet_handle’ has no member named ‘facet_begin’/
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compilation-errors-while-extending-Polyhedron-3-tp4656746p4656753.html
- [cgal-discuss] Compilation errors while extending Polyhedron_3, NMoreau, 02/17/2013
- Re: [cgal-discuss] Compilation errors while extending Polyhedron_3, Philipp Moeller, 02/17/2013
- [cgal-discuss] Re: Compilation errors while extending Polyhedron_3, NMoreau, 02/18/2013
- Re: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3, Philipp Moeller, 02/18/2013
- Re: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3, Laurent Rineau (CGAL/GeometryFactory), 02/18/2013
