cgal-discuss - [cgal-discuss] Re: Compilation errors while extending Polyhedron_3
  • To:
  • Subject: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3
  • Date: Mon, 18 Feb 2013 07:46:29 -0800 (PST)
Philipp Moeller-2 wrote
> AFAIK code like this would actually compile and work on older versions
> of Visual Studio.
Okay, I understand better why this was not working! Thanks.
> You are now passing a pointer to a handle and calling f->facet_begin()
> will try to find the member in the handle, while the member is in the
> object pointed to by the handle (handles are an abstraction over
> pointers). So, you would need to call `(*f)->facet_begin()`, where f is
> an object of type `Facet_handle*`. However, your original code should be
> the right way to do it. The original error (which you unfortunately
> snipped from your response) makes me think that there is a type between
> Face_handle and Facet_handle somewhere.
Actually that is what I thought at first and I tried to compare Facet_handle
et Face_handle, but I didn't manage to find out the problem... So here is
the error message I omitted in my last answer.
*In file included from ExtendedPolyhedron.h:11:0,
from Mesh.h:33,
from Mesh.cpp:22:*
*normal_cycle.h: In member function *
/‘void
Normal_cycle<_Poly>::principal_curvature_per_vert(Normal_cycle<_Poly>::Vertex,
double (*)[3])
[with _Poly = ExtendedPolyhedron<CGAL::Simple_cartesian&lt;float>,
ExtendedItems>,
Normal_cycle<_Poly>::Vertex =
CGAL::HalfedgeDS_in_place_list_vertex<
CGAL::I_Polyhedron_vertex<
ExtendedVertex<
CGAL::HalfedgeDS_list_types<CGAL::Simple_cartesian&lt;float>,
CGAL::I_Polyhedron_derived_items_3<ExtendedItems>, std::allocator<int> >,
CGAL::Boolean_tag<true>,
CGAL::Point_3<CGAL::Simple_cartesian&lt;float> >,
CGAL::Vector_3<CGAL::Simple_cartesian&lt;float> >,
float
*normal_cycle.h:69:3: instantiated from ‘void
Normal_cycle<_Poly>::principal_curvature(Normal_cycle<_Poly>::Polyhedron&,
bool, double) *
/[with _Poly = ExtendedPolyhedron<CGAL::Simple_cartesian&lt;float>,
ExtendedItems>,
Normal_cycle<_Poly>::Polyhedron =
ExtendedPolyhedron<CGAL::Simple_cartesian&lt;float>, ExtendedItems>]’/
*ExtendedPolyhedron.h:158:9: instantiated from ‘void
ExtendedPolyhedron<kernel, items>::computeNormalCycle(bool,
ExtendedPolyhedron<kernel, items>::FT) *
/[with kernel = CGAL::Simple_cartesian<float>,
items = ExtendedItems,
ExtendedPolyhedron<kernel, items>::FT = float]’/
*Mesh.cpp:290:42: instantiated from here*
*normal_cycle.h:211:2: erreur: no matching function for call to *
/‘Normal_cycle<ExtendedPolyhedron&lt;CGAL::Simple_cartesian&lt;float>,
ExtendedItems> >::AreaFacetTriangle(
CGAL::I_Polyhedron_halfedge<
ExtendedHalfedge<
CGAL::Boolean_tag<true> > >::Face_handle)’/
*normal_cycle.h:211:2: note: candidate is:*
*normal_cycle.h:343:9: note: double
Normal_cycle<_Poly>::AreaFacetTriangle(Normal_cycle<_Poly>::Facet_handle&) *
ExtendedItems>,
Normal_cycle<_Poly>::Facet_handle =
CGAL::internal::In_place_list_iterator<
CGAL::HalfedgeDS_in_place_list_face<
CGAL::I_Polyhedron_facet<
ExtendedFacet<
std::allocator<
ExtendedFacet<
std::allocator<int>
*normal_cycle.h:343:9: note: no known conversion for argument 1 from *
/‘CGAL::I_Polyhedron_halfedge<
ExtendedHalfedge<
>::Face_handle /
/{*aka *CGAL::internal::In_place_list_iterator<
ExtendedFacet<
std::allocator<
ExtendedFacet<
*to ‘Normal_cycle<ExtendedPolyhedron&lt;CGAL::Simple_cartesian&lt;float>,
ExtendedItems> >::Facet_handle&*
ExtendedFacet<
std::allocator<
ExtendedFacet<
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/Compilation-errors-while-extending-Polyhedron-3-tp4656746p4656756.html
