cgal-discuss - Re: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3
  • To:
  • Cc: NMoreau <>
  • Subject: Re: [cgal-discuss] Re: Compilation errors while extending Polyhedron_3
  • Date: Mon, 18 Feb 2013 17:22:35 +0100
Le lundi 18 février 2013 07:46:29 NMoreau a écrit :
> Actually that is what I thought at first and I tried to compare Facet_handle
> et Face_handle, but I didn't manage to find out the problem... So here is
> the error message I omitted in my last answer.
You are trying to pass a 'Polyhedron::Face_handle' to a function that takes a
'Normal_cycle::Facet_handle&'. The two type Face_handle and Facet_handle are
identical, which is good, *but* you are trying to pass a rvalue to a function
that wants a reference. That explains the compilation error.
Anyway, Philipp is right. Do not expect much help from the mailing list if
you
do not show the code that does not compile.
Laurent Rineau, PhD
