cgal-discuss - Re: [cgal-discuss] Re[4]: Triangulation optimization around special points
  • To:
  • Subject: Re: [cgal-discuss] Re[4]: Triangulation optimization around special points
  • Date: Mon, 11 Mar 2013 07:08:41 +0100
Since snap rounding in 3D is not easy, I think you should compute the
intersecting polyline using exact arithmetic and then simplify the output.
For the computation of intersecting polylines, you might want to
have a look at the non-documented function in CGAL/intersection_of_Polyhedra_3.h
template <typename Polyhedron, typename OutputIterator>
OutputIterator
intersection_Polyhedron_3_Polyhedron_3(const Polyhedron& P, const Polyhedron& Q, OutputIterator out)
where out expects object of type std::vector<typename Kernel::Point_3> representing a polyline
Sebastien.
On 03/07/2013 11:47 AM, Oleg wrote:
Yes, more general shapes. The final goal is to make uniform meshes for
bodies composed of general shapes with sharp boundaries between them.
Oleg
Thursday, March 7, 2013, 17:23, you wrote:
> What is the final goal? Only mesh 3 spheres? mesh n spheres? or more
> general shapes?
> I ask the question because the answer then varies.
> Sebastien.
> On 03/07/2013 11:16 AM, Oleg wrote:
>> Thursday, March 7, 2013, 16:53, you wrote:
>> > Le jeudi 07 mars 2013 00:00:11 Oleg a écrit :
>> >> Hello everyone! I have a question regarding triangulation
>> optimization. I
>> >> make a mesh for 3 balls intersection with 3 1D features. The mesh is
>> uniform
>> >> everywhere except 2 points where the 3 boundaries intersect:
>> >> <http://cgal-discuss.949826.n4.nabble.com/file/n4656843/3balls.gif>
>> >> These points don't seem to represent any problem for a manual
meshing,
>> >> because the boundaries intersect at large angles. Is there any easy
>> way to
>> >> optimize the mesh around these points to avoid the unnecessary
>> crowding? Any
>> >> ideas will be greatly appreciated.
>> > In your example, I assume that you have computed the intersections of
>> spheres
>> > and set them as 1D features of the domain. When 1D-features
>> intersect, you
>> > need to split them first at the intersection points. That will
make the
>> > special intersections points as "corner points" of the domain, and
>> fix the
>> > crowding you see in the result.
>> You're right, that's what I did. I'll try what you recommend, thanks!
>> Just another quick question - what would be the best way to find
>> intersection points of two polylines? Keeping in mind that the
>> polylines may not intersect in one exact point but rather pass by
>> each other at a small distance..?
>> Oleg
>> View this message in context: Re[2]: Triangulation optimization around
>> special points
<http://cgal-discuss.949826.n4.nabble.com/Triangulation-optimization-around-special-points-tp4656843p4656846.html>
>> Sent from the cgal-discuss mailing list archive
>> <http://cgal-discuss.949826.n4.nabble.com/> at Nabble.com.
View this message in context: Re[4]: Triangulation optimization around
special points
<http://cgal-discuss.949826.n4.nabble.com/Triangulation-optimization-around-special-points-tp4656843p4656848.html>
