[cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library
- To:
- Subject: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library
- Date: Tue, 12 Mar 2013 03:13:18 -0700 (PDT)
Dear Dr. Rineau,
Thank you very much for so good news. Currently I am using 4.1. I want to
know whether the following two problems are solved or not in 4.2:
1) the 4.1 doesn't support Intel C++ compiler (many errors when compiling by
Windows 7 64bit + VS2010 + Intel C++ 13.0);
2) the boolean operations to Nef_polyhedron results many duplicate nodes.
Furthermore, when two objects have common faects which are tangent, the
common facets can't be removed when do the '+' operation.
Thanks,
Zhanghong Tang
View this message in context:
http://cgal-discuss.949826.n4.nabble.com/CGAL-4-2-Beta-1-Released-Computational-Geometry-Algorithms-Library-tp4656859p4656912.html
- [cgal-discuss] CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 03/08/2013
- [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library, tang, 03/12/2013
- Re: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 03/12/2013
- [cgal-discuss] comparing C++ compilers on CGAL, W Randolph Franklin, 03/13/2013
