Re: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library
- To:
- Subject: Re: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library
- Date: Tue, 12 Mar 2013 14:07:58 +0100
Le mardi 12 mars 2013 04:53:51 tang a écrit :
> Dear Dr. Rineau,
> Thank you very much for your kindly reply.
> I have tested the 4.2 by Intel C++ compiler and the error information is as
> follows:
> Error 2 error : identifier "ilogb" is undefined
> E:\Users\tang\tang\mesh\CGAL\CGAL4.2\64bit_MT\include\CGAL\CORE\Filter.h
126
> 1 CGAL_Core
> Error 3 error : identifier "ilogb" is undefined
Unfortunately, the CGAL project does not (yet) support the Intel C++ Compiler
(icpc) on Windows. I know and understand the issue but that would need some
work.
I suggest you try to compile with the CMake variable WITH_CGAL_Core set to
OFF. That may be sufficient so that you can use icpc with CGAL-4.2.
Laurent Rineau, PhD
- [cgal-discuss] CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 03/08/2013
- [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library, tang, 03/12/2013
- Re: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library, Laurent Rineau (CGAL/GeometryFactory), 03/12/2013
- [cgal-discuss] comparing C++ compilers on CGAL, W Randolph Franklin, 03/13/2013
