cgal-discuss - Re: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library
  • To:
  • Subject: Re: [cgal-discuss] Re: CGAL 4.2 Beta 1 Released, Computational Geometry Algorithms Library
  • Date: Tue, 12 Mar 2013 11:51:09 +0100
Le mardi 12 mars 2013 03:13:18 tang a écrit :
> Dear Dr. Rineau,
> Thank you very much for so good news. Currently I am using 4.1. I want to
> know whether the following two problems are solved or not in 4.2:
> 1) the 4.1 doesn't support Intel C++ compiler (many errors when compiling by
> Windows 7 64bit + VS2010 + Intel C++ 13.0);
During the development of CGAL-4.2, the Intel C++ Compiler 13 was tested, and
supported, but only on a Linux machine. You should switch to 4.2 to try.
If you still have issue with icpc 13, and CGAL-4.2 on Windows, please send me
the output of the first errors. Are they compilation or linking errors, by
the
way?
> 2) the boolean operations to Nef_polyhedron results many duplicate nodes.
> Furthermore, when two objects have common faects which are tangent, the
> common facets can't be removed when do the '+' operation.
You should report you bug to the cgal-discuss mailing list. One college of
mine could answer. I do not know the answer myself. That bug is not mentioned
in the release notes for CGAL-4.2.
Best regards.
Laurent Rineau, PhD
